Salta al contenuto principale
Holmes HEH8031 Control Buttons Replacement
Cosa ti serve
  1. Holmes HEH8031 Control Buttons Replacement, Housing: passo 1, immagine 1 di 1
    • Ensure the device is unplugged from the wall outlet.
    Chiedi a FixBot
    Aggiungi Commento
  2. Holmes HEH8031 Control Buttons Replacement: passo 2, immagine 1 di 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
    Chiedi a FixBot
    Aggiungi Commento
  3. Holmes HEH8031 Control Buttons Replacement: passo 3, immagine 1 di 2 Holmes HEH8031 Control Buttons Replacement: passo 3, immagine 2 di 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
    Chiedi a FixBot
    Aggiungi Commento
  4. Holmes HEH8031 Control Buttons Replacement, Circuit Board Removal: passo 4, immagine 1 di 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  5. Holmes HEH8031 Control Buttons Replacement, Control Buttons: passo 5, immagine 1 di 3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: passo 5, immagine 2 di 3 Holmes HEH8031 Control Buttons Replacement, Control Buttons: passo 5, immagine 3 di 3
    • Remove the two Phillips #2 12mm screws from the button retainer.
    • Lift the button retainer off.
    • Remove the interconnected buttons.
    • If the buttons are broken, replace them.
    • If the buttons are sticking, clean them in warm soapy water and allow to dry.
    Chiedi a FixBot
    Aggiungi Commento
  6. Holmes HEH8031 Control Buttons Replacement: passo 6, immagine 1 di 3 Holmes HEH8031 Control Buttons Replacement: passo 6, immagine 2 di 3 Holmes HEH8031 Control Buttons Replacement: passo 6, immagine 3 di 3
    • Using light finger pressure, carefully push the black plastic tabs off the white plastic hooks.
    • Remove the black plastic bracket out through the front of the heater housing.
    • Remove the two Phillips #2 12mm screws and remove the clear window from the black plastic bracket.
    • If the buttons were sticking, clean the black plastic bracket in warm soapy water and allow to dry.
    • If the clear window was dirty, clean it in warm soapy water and allow to dry.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
IUPUI, Team 2-1, Baechle Fall 2016 Membro di IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 6
Ultimi 30 giorni: 25
Tutti i Tempi: 837
