Salta al contenuto principale
Hitachi CP-X440 Sensor Replacement
Cosa ti serve
  1. Hitachi CP-X440 Sensor Replacement, Sensor: passo 1, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the six 2 cm screws from the bottom of the case.
    Chiedi a FixBot
    Aggiungi Commento
  2. Hitachi CP-X440 Sensor Replacement: passo 2, immagine 1 di 2 Hitachi CP-X440 Sensor Replacement: passo 2, immagine 2 di 2
    • Flip the projector back upright and place the back of projector towards you. Unscrew the 3 screws circled in the back with your Phillips #1 Screwdriver. Each screw is 1 cm in length.
    • Then unscrew the two silver, 1 cm screws on the light switch panel with a Phillips #1 Screwdriver
    Chiedi a FixBot
    Aggiungi Commento
  3. Hitachi CP-X440 Sensor Replacement: passo 3, immagine 1 di 3 Hitachi CP-X440 Sensor Replacement: passo 3, immagine 2 di 3 Hitachi CP-X440 Sensor Replacement: passo 3, immagine 3 di 3
    • You will now be able to pop the top of the projector off.
    • To uncollapse the projector top fully from the projector, you can pull the black cord from the white holder near the lens, circled in red and orange.
    • With front of projector now facing you, the sensor can be found on the left of the lens.
    Chiedi a FixBot
    Aggiungi Commento
  4. Hitachi CP-X440 Sensor Replacement: passo 4, immagine 1 di 2 Hitachi CP-X440 Sensor Replacement: passo 4, immagine 2 di 2
    • The sensor will be held into the projector by a silver screw on the lower left side of lens. This single 2 mm screw will need to be unscrewed and removed. This will allow you to remove the sensor piece completely out of the projector.
    • You now will remove the sensor piece completely.
    Chiedi a FixBot
    Aggiungi Commento
  5. Hitachi CP-X440 Sensor Replacement: passo 5, immagine 1 di 3 Hitachi CP-X440 Sensor Replacement: passo 5, immagine 2 di 3 Hitachi CP-X440 Sensor Replacement: passo 5, immagine 3 di 3
    • To get the sensor piece alone, you will unscrew the single 3 mm silver screw.
    • Once this screw in the sensor piece is removed, the sensor piece will be alone and can be replaced with your new one.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 369
