Salta al contenuto principale
Harman Kardon Esquire Mini External Stand Replacement
Cosa ti serve
    1. Harman Kardon Esquire Mini External Stand  Replacement, Front Panel: passo 1, immagine 1 di 1
      • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
      • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
      Chiedi a FixBot
      Aggiungi Commento
    2. Harman Kardon Esquire Mini External Stand  Replacement: passo 2, immagine 1 di 1
      • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
      • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
      • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    1. Harman Kardon Esquire Mini External Stand  Replacement, External Stand: passo 3, immagine 1 di 1
      • Using the Pentalobe screw driver, unscrew the 5.1 mm screws by applying a clockwise force.
      • Remove all of the 5.1 mm screws, and slowly lift the stand. There are 4 screws on the stand.
      • After the stand is removed, replace the stand with a new one.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S1-G9, Cagle Fall 2017 Membro di USF Tampa, Team S1-G9, Cagle Fall 2017
USFT-CAGLE-F17S1G9
5 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 34
Tutti i Tempi: 981
