Salta al contenuto principale
Hamilton Beach 51101BA Power Button Replacement
Cosa ti serve
    1. Hamilton Beach 51101BA Power Button Replacement, Power Button: passo 1, immagine 1 di 3 Hamilton Beach 51101BA Power Button Replacement, Power Button: passo 1, immagine 2 di 3 Hamilton Beach 51101BA Power Button Replacement, Power Button: passo 1, immagine 3 di 3
      • Remove the container from the base.
      • Hold the blender and the container, then twist the container in a clockwise motion.
      • Make sure to follow the lock and unlock markings on the container.
      Chiedi a FixBot
      Aggiungi Commento
    2. Hamilton Beach 51101BA Power Button Replacement: passo 2, immagine 1 di 1
      • Turn the blender so the bottom is facing you.
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
      Chiedi a FixBot
      Aggiungi Commento
    3. Hamilton Beach 51101BA Power Button Replacement: passo 3, immagine 1 di 1
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
      Chiedi a FixBot
      Aggiungi Commento
    4. Hamilton Beach 51101BA Power Button Replacement: passo 4, immagine 1 di 2 Hamilton Beach 51101BA Power Button Replacement: passo 4, immagine 2 di 2
      • Unhinge the motor platform from the blender.
      • You may need a plastic spudger to unhinge the plastic bottom piece from the base of the blender.
      • You do not need to completely remove this piece from the base.
      Chiedi a FixBot
      Aggiungi Commento
    5. Hamilton Beach 51101BA Power Button Replacement: passo 5, immagine 1 di 1
      • Pull out the rectangular green piece.
      • This is the actual power button.
      Chiedi a FixBot
      Aggiungi Commento
    6. Hamilton Beach 51101BA Power Button Replacement: passo 6, immagine 1 di 1
      • Some experience in soldering is required!
      • On the back of the power button, desolder the red and grey wires that are connected to the piece.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 2-5, Sullivan Fall 2015 Membro di USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 30
Tutti i Tempi: 4,051
