Salta al contenuto principale
Hamilton Beach 25460Z Handle Replacement
Cosa ti serve
    1. Hamilton Beach 25460Z Handle Replacement, Handle: passo 1, immagine 1 di 2 Hamilton Beach 25460Z Handle Replacement, Handle: passo 1, immagine 2 di 2
      • Unplug your device before proceeding with disassembly.
      • On the back of the press, remove the locking washer by prying upwards with the nylon or metal spudger tool.
      • Repeat for the other washer across from the first one.
      Chiedi a FixBot
      Aggiungi Commento
    2. Hamilton Beach 25460Z Handle Replacement: passo 2, immagine 1 di 2 Hamilton Beach 25460Z Handle Replacement: passo 2, immagine 2 di 2
      • Using any long, thin object, push the 43mm bolt from the inside towards the outside to expose the end of the bolt.
      • Pull the end of the bolt out to completely remove it.
      • Repeat for the second bolt.
      Chiedi a FixBot
      Aggiungi Commento
    3. Hamilton Beach 25460Z Handle Replacement: passo 3, immagine 1 di 2 Hamilton Beach 25460Z Handle Replacement: passo 3, immagine 2 di 2
      • Using the 4.0mm Allen Wrench, unscrew the two 26mm bolts connecting the handle to the upper heating element housing on both sides.
      Chiedi a FixBot
      Aggiungi Commento
    4. Hamilton Beach 25460Z Handle Replacement: passo 4, immagine 1 di 1
      • Unscrew the locking knob all the way to remove it.
      Chiedi a FixBot
      Aggiungi Commento
    5. Hamilton Beach 25460Z Handle Replacement: passo 5, immagine 1 di 3 Hamilton Beach 25460Z Handle Replacement: passo 5, immagine 2 di 3 Hamilton Beach 25460Z Handle Replacement: passo 5, immagine 3 di 3
      • Slide the locking knob couple down to the base of the handle, then pull up on the free end of the handle. It will easily pop off.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team 6-27, Amido Winter 2015 Membro di Cal Poly, Team 6-27, Amido Winter 2015
CPSU-AMIDO-W15S6G27
4 Membri
12 guide realizzate
2Commenti sulla guida
And where do I buy the handle?? I can’t find it anywhere
if someone see this, please help me!
Tulio
Tulioalejandro@icloud.com
tulio181 - Rispondi Condividi
I too am looking for a replacement handle! They get brittle from the heat...mine just snapped on the left side..
salikah11@yahoo.ca
DEE EFF - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 38
Tutti i Tempi: 2,456
