Salta al contenuto principale
HTC Wizard 100 Camera Replacement
Cosa ti serve
  1. HTC Wizard 100 Camera Replacement, Battery: passo 1, immagine 1 di 2 HTC Wizard 100 Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC Wizard 100 Camera Replacement: passo 2, immagine 1 di 2 HTC Wizard 100 Camera Replacement: passo 2, immagine 2 di 2
    • Pull on the plastic tab to release the battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC Wizard 100 Camera Replacement, Back Case: passo 3, immagine 1 di 2 HTC Wizard 100 Camera Replacement, Back Case: passo 3, immagine 2 di 2
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC Wizard 100 Camera Replacement: passo 4, immagine 1 di 1
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
    Chiedi a FixBot
    Aggiungi Commento
  5. HTC Wizard 100 Camera Replacement: passo 5, immagine 1 di 3 HTC Wizard 100 Camera Replacement: passo 5, immagine 2 di 3 HTC Wizard 100 Camera Replacement: passo 5, immagine 3 di 3
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
    Chiedi a FixBot
    Aggiungi Commento
  6. HTC Wizard 100 Camera Replacement, Camera: passo 6, immagine 1 di 1
    • Locate the camera and pry off with the plastic opening tool or spudger.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 20-28, Maness Fall 2011 Membro di Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Membri
21 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 20
Tutti i Tempi: 1,058
