Introduzione
Use this guide to replace the motherboard in an HTC Vive Cosmos.
Make sure that the Vive Cosmos is powered off and disconnected from power before beginning disassembly.
Cosa ti serve
Pull the bottom of the facerest straight away from the Vive Cosmos to unclip it from the Vive.
With the bottom unclipped, pull the top of the facerest away from the Vive to remove it.
Use your finger to push the sliding faceplate release switch, sitting to the left of the lenses, toward the bottom of the Vive.
While holding the switch in the bottom position, pull the faceplate straight up and away from the front of the Vive.
Remove the faceplate.
Use a T5 Torx driver to remove the 4.1 mm long screw securing the focus knob.
Slide the focus knob out of the plastic housing, off of the focus rod, and remove it.
Twist the 3.5 mm audio connector counter-clockwise slightly and slide its cable out from under the plastic retaining clip.
Lift the audio connector straight up to unplug it.
Use a T5 Torx driver to remove the three 4.1 mm long screws securing the LCD and motherboard assembly.
Remove the microphone cover from the bottom edge of the headset.
Slide an opening pick under the microphone to separate the adhesive securing it to the Vive.
Angle the bottom end of the upper component cover away from the front of the Vive.
Pull the upper component cover away from the front of the Vive and remove it.
Slide the camera connector covers on either side of the LCD and motherboard assembly away from the center off of the assembly and remove them.
Peel the tape over the right camera connector back enough to access the camera's ZIF connector underneath.
Repeat the same process to peel back the tape over the left camera ZIF connector.
Lift the LCD and motherboard assembly out of the headset.
Use a T5 Torx driver to remove the four 2.9 mm long screws securing the LCD connectors.
Gently pull the bottom edge of the midframe away from the bottom edges of the LCD frames to unclip the LCD frames from the midframe.
Peel the yellow tape off of the headset button connector.
Peel the black plastic sticker off of the left side of the motherboard.
Use the flat end of a spudger to flip up the locking flap securing the left camera cable ZIF connector.
Carefully slide the camera cable straight out of its socket on the motherboard.
Peel the yellow tape off of both the second interconnect cable and its socket on the motherboard.
Peel the black plastic sticker off of the right side of the motherboard.
Use a T5 Torx driver to remove the screws securing the motherboard, heat sink, and fan:
Five 4.1 mm long screws
One 8.5 mm long screw
Use the flat end of a spudger to gently pry the heat sink off of the CPU.
Hinge the top end of the motherboard slightly away from the midframe.
Slide the motherboard up and out of the clips holding its bottom edge against the midframe.
