Salta al contenuto principale
HTC Vive Controller Saucer Replacement
Cosa ti serve
    1. HTC Vive Controller Saucer Replacement, Saucer Panels: passo 1, immagine 1 di 3 HTC Vive Controller Saucer Replacement, Saucer Panels: passo 1, immagine 2 di 3 HTC Vive Controller Saucer Replacement, Saucer Panels: passo 1, immagine 3 di 3
      • Turn over the Vive controller so that the bottom saucer is facing up.
      • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
      Chiedi a FixBot
      Aggiungi Commento
    2. HTC Vive Controller Saucer Replacement: passo 2, immagine 1 di 2 HTC Vive Controller Saucer Replacement: passo 2, immagine 2 di 2
      • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
      • Remove only the top saucer cover by pulling up with your hand.
      Chiedi a FixBot
      Aggiungi Commento
    3. HTC Vive Controller Saucer Replacement: passo 3, immagine 1 di 2 HTC Vive Controller Saucer Replacement: passo 3, immagine 2 di 2
      • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
      Chiedi a FixBot
      Aggiungi Commento
    4. HTC Vive Controller Saucer Replacement: passo 4, immagine 1 di 3 HTC Vive Controller Saucer Replacement: passo 4, immagine 2 di 3 HTC Vive Controller Saucer Replacement: passo 4, immagine 3 di 3
      • Carefully pull away the bottom saucer cover with your hand.
      • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team S15-G5, Livingston Fall 2017 Membro di Cal Poly, Team S15-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G5
4 Membri
68 guide realizzate
3Commenti sulla guida
Where do you get the replacement parts?
dmitri.walker - Rispondi Condividi
Vive dont less these parts we need to 3D print them its a Nightmare RN for business especially arcades
superseani2 - Rispondi Condividi
My controller only has 2 screws that are different sizes than a t5 and the 3rd is completely covered up by plastic. I have the sticky button problem, halp pls
bizkidjordan - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 54
Tutti i Tempi: 7,312
