Salta al contenuto principale
HTC Vive Controller Grip Buttons Replacement
Cosa ti serve
  1. HTC Vive Controller Grip Buttons Replacement, Saucer Panels: passo 1, immagine 1 di 3 HTC Vive Controller Grip Buttons Replacement, Saucer Panels: passo 1, immagine 2 di 3 HTC Vive Controller Grip Buttons Replacement, Saucer Panels: passo 1, immagine 3 di 3
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC Vive Controller Grip Buttons Replacement: passo 2, immagine 1 di 2 HTC Vive Controller Grip Buttons Replacement: passo 2, immagine 2 di 2
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC Vive Controller Grip Buttons Replacement: passo 3, immagine 1 di 2 HTC Vive Controller Grip Buttons Replacement: passo 3, immagine 2 di 2
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC Vive Controller Grip Buttons Replacement: passo 4, immagine 1 di 3 HTC Vive Controller Grip Buttons Replacement: passo 4, immagine 2 di 3 HTC Vive Controller Grip Buttons Replacement: passo 4, immagine 3 di 3
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    Chiedi a FixBot
    Aggiungi Commento
  5. HTC Vive Controller Grip Buttons Replacement, Front Panel: passo 5, immagine 1 di 2 HTC Vive Controller Grip Buttons Replacement, Front Panel: passo 5, immagine 2 di 2
    • Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
    Chiedi a FixBot
    Aggiungi Commento
  6. HTC Vive Controller Grip Buttons Replacement: passo 6, immagine 1 di 1
    • Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
    • Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
    Chiedi a FixBot
    Aggiungi Commento
  7. HTC Vive Controller Grip Buttons Replacement: passo 7, immagine 1 di 2 HTC Vive Controller Grip Buttons Replacement: passo 7, immagine 2 di 2
    • Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
    • Only separate the front panel around the edges. Do not try to completely remove the panel yet.
    • Gently lift the right side of the panel to the left.
    Chiedi a FixBot
    Aggiungi Commento
  8. HTC Vive Controller Grip Buttons Replacement: passo 8, immagine 1 di 1
    • Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
    • Do not try to disconnect the ribbon cables from the front panel.
    Chiedi a FixBot
    Aggiungi Commento
  9. HTC Vive Controller Grip Buttons Replacement: passo 9, immagine 1 di 2 HTC Vive Controller Grip Buttons Replacement: passo 9, immagine 2 di 2
    • Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
    Chiedi a FixBot
    Aggiungi Commento
  10. HTC Vive Controller Grip Buttons Replacement: passo 10, immagine 1 di 3 HTC Vive Controller Grip Buttons Replacement: passo 10, immagine 2 di 3 HTC Vive Controller Grip Buttons Replacement: passo 10, immagine 3 di 3
    • Use the nylon spudger to lift the white tab by 90 degrees.
    • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
    Chiedi a FixBot
    Aggiungi Commento
  11. HTC Vive Controller Grip Buttons Replacement, Battery: passo 11, immagine 1 di 2 HTC Vive Controller Grip Buttons Replacement, Battery: passo 11, immagine 2 di 2
    • Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
    Chiedi a FixBot
    Aggiungi Commento
  12. HTC Vive Controller Grip Buttons Replacement: passo 12, immagine 1 di 1
    • Remove the silver plate by pinching it with two fingers and lifting up.
    Chiedi a FixBot
    Aggiungi Commento
  13. HTC Vive Controller Grip Buttons Replacement: passo 13, immagine 1 di 1
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the top left of the battery frame.
    Chiedi a FixBot
    Aggiungi Commento
  14. HTC Vive Controller Grip Buttons Replacement: passo 14, immagine 1 di 2 HTC Vive Controller Grip Buttons Replacement: passo 14, immagine 2 di 2
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame.
    Chiedi a FixBot
    Aggiungi Commento
  15. HTC Vive Controller Grip Buttons Replacement: passo 15, immagine 1 di 2 HTC Vive Controller Grip Buttons Replacement: passo 15, immagine 2 di 2
    • Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up.
    Chiedi a FixBot
    Aggiungi Commento
  16. HTC Vive Controller Grip Buttons Replacement: passo 16, immagine 1 di 3 HTC Vive Controller Grip Buttons Replacement: passo 16, immagine 2 di 3 HTC Vive Controller Grip Buttons Replacement: passo 16, immagine 3 di 3
    • Lift the battery frame to remove the battery from the Vive controller
    Chiedi a FixBot
    Aggiungi Commento
  17. HTC Vive Controller Grip Buttons Replacement, Motherboard: passo 17, immagine 1 di 1
    • Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the top of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  18. HTC Vive Controller Grip Buttons Replacement: passo 18, immagine 1 di 2 HTC Vive Controller Grip Buttons Replacement: passo 18, immagine 2 di 2
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  19. HTC Vive Controller Grip Buttons Replacement: passo 19, immagine 1 di 3 HTC Vive Controller Grip Buttons Replacement: passo 19, immagine 2 di 3 HTC Vive Controller Grip Buttons Replacement: passo 19, immagine 3 di 3
    • Use the nylon spudger to rotate the black tab up by 90 degrees.
    • Disconnect the ribbon cable carefully with your finger.
    Chiedi a FixBot
    Aggiungi Commento
  20. HTC Vive Controller Grip Buttons Replacement: passo 20, immagine 1 di 3 HTC Vive Controller Grip Buttons Replacement: passo 20, immagine 2 di 3 HTC Vive Controller Grip Buttons Replacement: passo 20, immagine 3 di 3
    • Lift the motherboard up and out of the Vive controller using your hands.
    Chiedi a FixBot
    Aggiungi Commento
  21. HTC Vive Controller Grip Buttons Replacement, Grip Buttons: passo 21, immagine 1 di 1
    • Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the silver rectangular plate.
    Chiedi a FixBot
    Aggiungi Commento
  22. HTC Vive Controller Grip Buttons Replacement: passo 22, immagine 1 di 1
    • Lift the silver rectangular plate up and out of the controller using your hand.
    Chiedi a FixBot
    Aggiungi Commento
  23. HTC Vive Controller Grip Buttons Replacement: passo 23, immagine 1 di 3 HTC Vive Controller Grip Buttons Replacement: passo 23, immagine 2 di 3 HTC Vive Controller Grip Buttons Replacement: passo 23, immagine 3 di 3
    • Use the nylon spudger to lift the bottom rubber tab on the inside of the right grip button.
    • Use the nylon spudger to lift the top rubber tab on the inside of the right grip button.
    Chiedi a FixBot
    Aggiungi Commento
  24. HTC Vive Controller Grip Buttons Replacement: passo 24, immagine 1 di 2 HTC Vive Controller Grip Buttons Replacement: passo 24, immagine 2 di 2
    • Push the grip button in with your finger until it pops out of its socket.
    • You may hear a popping sound when you pop out the grip button
    • Repeat steps 23 and 24 to remove the left side grip button.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S15-G5, Livingston Fall 2017 Membro di Cal Poly, Team S15-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G5
4 Membri
59 guide realizzate
2Commenti sulla guida
It’s all fine and dandy but this part is nowhere to be found
olivier.ducran2 - Rispondi Condividi
Hi, first of all ty for the tools and all the effort.
During disassembly my system button's 7 contanct fpc connector ripped apart and cant find any label on it.
I am trying to find a replacement part to re-solder it.
Can you help me with a name of that connector.
Thanks
Zoltán Táborosi - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 35
Tutti i Tempi: 5,867
