Salta al contenuto principale
HTC Vive Controller Front Panel Buttons Replacement
Cosa ti serve
  1. HTC Vive Controller Front Panel Buttons Replacement, Saucer Panels: passo 1, immagine 1 di 3 HTC Vive Controller Front Panel Buttons Replacement, Saucer Panels: passo 1, immagine 2 di 3 HTC Vive Controller Front Panel Buttons Replacement, Saucer Panels: passo 1, immagine 3 di 3
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC Vive Controller Front Panel Buttons Replacement: passo 2, immagine 1 di 2 HTC Vive Controller Front Panel Buttons Replacement: passo 2, immagine 2 di 2
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC Vive Controller Front Panel Buttons Replacement: passo 3, immagine 1 di 2 HTC Vive Controller Front Panel Buttons Replacement: passo 3, immagine 2 di 2
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC Vive Controller Front Panel Buttons Replacement: passo 4, immagine 1 di 3 HTC Vive Controller Front Panel Buttons Replacement: passo 4, immagine 2 di 3 HTC Vive Controller Front Panel Buttons Replacement: passo 4, immagine 3 di 3
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    Chiedi a FixBot
    Aggiungi Commento
  5. HTC Vive Controller Front Panel Buttons Replacement, Front Panel: passo 5, immagine 1 di 2 HTC Vive Controller Front Panel Buttons Replacement, Front Panel: passo 5, immagine 2 di 2
    • Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
    Chiedi a FixBot
    Aggiungi Commento
  6. HTC Vive Controller Front Panel Buttons Replacement: passo 6, immagine 1 di 1
    • Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
    • Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
    Chiedi a FixBot
    Aggiungi Commento
  7. HTC Vive Controller Front Panel Buttons Replacement: passo 7, immagine 1 di 2 HTC Vive Controller Front Panel Buttons Replacement: passo 7, immagine 2 di 2
    • Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
    • Only separate the front panel around the edges. Do not try to completely remove the panel yet.
    • Gently lift the right side of the panel to the left.
    Chiedi a FixBot
    Aggiungi Commento
  8. HTC Vive Controller Front Panel Buttons Replacement: passo 8, immagine 1 di 1
    • Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
    • Do not try to disconnect the ribbon cables from the front panel.
    Chiedi a FixBot
    Aggiungi Commento
  9. HTC Vive Controller Front Panel Buttons Replacement: passo 9, immagine 1 di 2 HTC Vive Controller Front Panel Buttons Replacement: passo 9, immagine 2 di 2
    • Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
    Chiedi a FixBot
    Aggiungi Commento
  10. HTC Vive Controller Front Panel Buttons Replacement: passo 10, immagine 1 di 3 HTC Vive Controller Front Panel Buttons Replacement: passo 10, immagine 2 di 3 HTC Vive Controller Front Panel Buttons Replacement: passo 10, immagine 3 di 3
    • Use the nylon spudger to lift the white tab by 90 degrees.
    • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
    Chiedi a FixBot
    Aggiungi Commento
  11. HTC Vive Controller Front Panel Buttons Replacement, Front Panel Buttons: passo 11, immagine 1 di 3 HTC Vive Controller Front Panel Buttons Replacement, Front Panel Buttons: passo 11, immagine 2 di 3 HTC Vive Controller Front Panel Buttons Replacement, Front Panel Buttons: passo 11, immagine 3 di 3
    • Use the T5 Torx head screwdriver to remove the two silver 4.2mm screws from rear plastic cover of the system button.
    Chiedi a FixBot
    Aggiungi Commento
  12. HTC Vive Controller Front Panel Buttons Replacement: passo 12, immagine 1 di 2 HTC Vive Controller Front Panel Buttons Replacement: passo 12, immagine 2 di 2
    • Lift the plastic cover up and out of the front panel using your hand.
    Chiedi a FixBot
    Aggiungi Commento
  13. HTC Vive Controller Front Panel Buttons Replacement: passo 13, immagine 1 di 2 HTC Vive Controller Front Panel Buttons Replacement: passo 13, immagine 2 di 2
    • Push the system button with your finger until it pops out of the front panel.
    Chiedi a FixBot
    Aggiungi Commento
  14. HTC Vive Controller Front Panel Buttons Replacement: passo 14, immagine 1 di 3 HTC Vive Controller Front Panel Buttons Replacement: passo 14, immagine 2 di 3 HTC Vive Controller Front Panel Buttons Replacement: passo 14, immagine 3 di 3
    • Use the T5 Torx head screwdriver to remove the two silver 4.2mm screws from rear portion of the trackpad.
    • Lift the trackpad up and out of the panel using your hand.
    Chiedi a FixBot
    Aggiungi Commento
  15. HTC Vive Controller Front Panel Buttons Replacement: passo 15, immagine 1 di 2 HTC Vive Controller Front Panel Buttons Replacement: passo 15, immagine 2 di 2
    • Use the T5 Torx head screwdriver to remove the two silver 4.2mm screws from the rear plastic cover of the menu button.
    • You may need to fold the ribbon cable to the left in order to expose the second silver screw.
    Chiedi a FixBot
    Aggiungi Commento
  16. HTC Vive Controller Front Panel Buttons Replacement: passo 16, immagine 1 di 1
    • Lift the plastic cover up and out of the panel using your hand.
    Chiedi a FixBot
    Aggiungi Commento
  17. HTC Vive Controller Front Panel Buttons Replacement: passo 17, immagine 1 di 2 HTC Vive Controller Front Panel Buttons Replacement: passo 17, immagine 2 di 2
    • Push the menu button with your finger until it pops out of the front panel.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
Cal Poly, Team S15-G5, Livingston Fall 2017 Membro di Cal Poly, Team S15-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G5
4 Membri
59 guide realizzate
5Commenti sulla guida
Okay great! But where can I buy replacement parts?
Colton Hoffman - Rispondi Condividi
Thanks for the guide! Even though iFixit doesn’t have the replacement parts, I was able to fix my button that was off-center and get my controller back up and running! The only issue is that with step 5, the T5 screwdriver that comes with the iFixit tool kits doesn’t work, as it’s too wide. I had to go out and buy a narrower driver, but still much less expensive than the controller. Thanks again!
Ryan Sandberg - Rispondi Condividi
I had my front panel TOUCHPAD STUCK, in the sense it could sense my thumb touch, but NOT my thumb press on the upper-right part (presses on the other directions were detected). I figured out how to fix it:
The touchpad presses are detected by a little sensor on the controller: it’s the little pink button we can see on the picture of Step 8 on the dark-blue board. This button is pressed when pressing the touchpad, via a little black round plastic thingy behind the very center of the touchpad : we can see it on the top of picture of Step 11, the little black circle. If this black circle is off-center or simply *too low*, the contact with the pink button will not happen properly. I personnaly got the black circle thingy off, placed another thin layer of material below it (of approximately the size of the thingy) and placed it back, so it would be more in contact with the pink button. Solved on my both controllers !
Thanks for this really good guide which helped me solve this !
Jesuis Une - Rispondi Condividi
Hi! My ribbon cable to the touchpad is damaged. Does anyonw know whre to buy a replacment? Seems like it’s soldered to the rumblepack also.
Andreas Andersson - Rispondi Condividi
I replaced the little disc that Jesuis Une was talking about with a piece of PTFE used for mouse skates. The disc is 5/32 or 4.0 mm. I used a punch to knock a piece of 0.6 mm PTFE from the excess edging and it works like a charm.
Eric Tong - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 64
Tutti i Tempi: 9,607
