Salta al contenuto principale
HTC Touch Pro 2 Keyboard Replacement
Cosa ti serve
  1. HTC Touch Pro 2 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 HTC Touch Pro 2 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 HTC Touch Pro 2 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC Touch Pro 2 Keyboard Replacement: passo 2, immagine 1 di 2 HTC Touch Pro 2 Keyboard Replacement: passo 2, immagine 2 di 2
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC Touch Pro 2 Keyboard Replacement, Housing: passo 3, immagine 1 di 2 HTC Touch Pro 2 Keyboard Replacement, Housing: passo 3, immagine 2 di 2
    • Using a T5 screwdriver, remove the four screws in corners as shown.
    • Lift the top portion of the rear case.
    • Potential for device damage: There is a ribbon attached on the back of this part that requires caution to remove.
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC Touch Pro 2 Keyboard Replacement: passo 4, immagine 1 di 3 HTC Touch Pro 2 Keyboard Replacement: passo 4, immagine 2 di 3 HTC Touch Pro 2 Keyboard Replacement: passo 4, immagine 3 di 3
    • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
    • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
    • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
    Chiedi a FixBot
    Aggiungi Commento
  5. HTC Touch Pro 2 Keyboard Replacement, Keyboard: passo 5, immagine 1 di 3 HTC Touch Pro 2 Keyboard Replacement, Keyboard: passo 5, immagine 2 di 3 HTC Touch Pro 2 Keyboard Replacement, Keyboard: passo 5, immagine 3 di 3
    • Peel off the yellow ribbon shown slowly.
    • Unscrew the fours screws shown in red squares (two in each square) using a 00 screwdriver.
    • After the screws are out, you will be able to easily take off the small metal pieces circled in red.
    Chiedi a FixBot
    Aggiungi Commento
  6. HTC Touch Pro 2 Keyboard Replacement: passo 6, immagine 1 di 3 HTC Touch Pro 2 Keyboard Replacement: passo 6, immagine 2 di 3 HTC Touch Pro 2 Keyboard Replacement: passo 6, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Slowly pull dual black strip off using force.
    • Behind the dual black strip is very sticky piece of grey tape. Use tweezers (preferably ones with ridges) to peel off the tape. Be careful not to rip it.
    Chiedi a FixBot
    Aggiungi Commento
  7. HTC Touch Pro 2 Keyboard Replacement: passo 7, immagine 1 di 2 HTC Touch Pro 2 Keyboard Replacement: passo 7, immagine 2 di 2
    • Lift ZIF connectors up.
    • Carefully lift keyboard frame away from display screen.
    • You now have the keyboard detached.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 9-64, Walters Spring 2011 Membro di Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Membri
27 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 32
Tutti i Tempi: 4,832
