Salta al contenuto principale
HTC One X Antenna Replacement
Cosa ti serve
  1. HTC One X Antenna Replacement, Squeeze Test: passo 1, immagine 1 di 1
    • Before replacement of the antenna, carry out the squeeze test.
    • Gently squeeze your device between the camera lens and the volume button. This should temporarily reconnect the antenna if it's loose.
    • If the squeeze test doesn't reconnect your wi-fi/bluetooth then move to step 2
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC One X Antenna Replacement, Remove SIM card slot: passo 2, immagine 1 di 1
    • Insert a safety pin, or other small object into the narrow aperture next to the Sim Card Slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC One X Antenna Replacement, Remove front panel: passo 3, immagine 1 di 2 HTC One X Antenna Replacement, Remove front panel: passo 3, immagine 2 di 2
    • Use a plastic opening tool, and carefully insert it between the display and rear panel. Separate the two parts.
    • The display assembly is a tight fit therefore the removal must be carried out carefully with firm, constant force being applied around the bottom corners and sides of the panel. Note that the top of the phone is underneath the panel, and will not come out.
    • If your display is cracked, take extra caution when separating the display from the rear panel to prevent further breakage or bodily harm.
    • Set aside the rear panel for now
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC One X Antenna Replacement, Replace antenna: passo 4, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Once the rear panel is separated from the front panel, remove the antenna using tweezers.
    • The antenna is located on the right hand side of the front panel as indicated in the image.
    • Replace and reconnect the new antenna in the same position as the faulty one you just removed. Remember to place it underneath the metal supports on the board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 4-3, Brown Fall 2014 Membro di USF Tampa, Team 4-3, Brown Fall 2014
USFT-BROWN-F14S4G3
3 Membri
19 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 32
Tutti i Tempi: 9,821
