Salta al contenuto principale
HTC One Mini 2 Battery Replacement
Cosa ti serve
  1. HTC One Mini 2 Battery Replacement, Sim and MicroSD Card: passo 1, immagine 1 di 3 HTC One Mini 2 Battery Replacement, Sim and MicroSD Card: passo 1, immagine 2 di 3 HTC One Mini 2 Battery Replacement, Sim and MicroSD Card: passo 1, immagine 3 di 3
    • Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
    • Set the cardholders aside.
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC One Mini 2 Battery Replacement: passo 2, immagine 1 di 1
    • Heat up the top grey speaker plate with the iFixit iOpener for two minutes.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC One Mini 2 Battery Replacement, Front Plate: passo 3, immagine 1 di 3 HTC One Mini 2 Battery Replacement, Front Plate: passo 3, immagine 2 di 3 HTC One Mini 2 Battery Replacement, Front Plate: passo 3, immagine 3 di 3
    • Use a metal spudger to pry up the left edge of the upper grey front plate.
    • Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
    • Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
    • Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC One Mini 2 Battery Replacement: passo 4, immagine 1 di 2 HTC One Mini 2 Battery Replacement: passo 4, immagine 2 di 2
    • Remove the 2mm screw with a T5 torx screwdriver head from the iFixit tool kit.
    Chiedi a FixBot
    Aggiungi Commento
  5. HTC One Mini 2 Battery Replacement: passo 5, immagine 1 di 2 HTC One Mini 2 Battery Replacement: passo 5, immagine 2 di 2
    • Use the plastic pry tool to pry around the edge of the phone.
    • Pry carefully around the card slots.
    • Slowly pull up from the right side of the screen like opening a book.
    • The plastic piece for the power button may fall out. Set it aside for reassembly.
    • Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
    Chiedi a FixBot
    Aggiungi Commento
  6. HTC One Mini 2 Battery Replacement, Motherboard: passo 6, immagine 1 di 2 HTC One Mini 2 Battery Replacement, Motherboard: passo 6, immagine 2 di 2
    • Peel off the long yellow pieces of tape on the right and left side of the copper plate.
    Chiedi a FixBot
    Aggiungi Commento
  7. HTC One Mini 2 Battery Replacement: passo 7, immagine 1 di 1
    • Starting from the copper plate, peel up all three woven, silver colored tapes using the spudger or narrow pry tool.
    Chiedi a FixBot
    Aggiungi Commento
  8. HTC One Mini 2 Battery Replacement: passo 8, immagine 1 di 3 HTC One Mini 2 Battery Replacement: passo 8, immagine 2 di 3 HTC One Mini 2 Battery Replacement: passo 8, immagine 3 di 3
    • Using the flat end of the spudger, pop up the white tabs on all ribbon cable connectors located to the left and right of the copper plate.
    • On the left side, pop the white tab up to the left. On the right, pop up to the right.
    • Carefully pull out the ribbon cables.
    Chiedi a FixBot
    Aggiungi Commento
  9. HTC One Mini 2 Battery Replacement: passo 9, immagine 1 di 3 HTC One Mini 2 Battery Replacement: passo 9, immagine 2 di 3 HTC One Mini 2 Battery Replacement: passo 9, immagine 3 di 3
    • Using a Phillips #00 screwdriver, unscrew the two 1 mm screws from the bottom right corner of the motherboard that hold the power connector down.
    • Pop up the battery connector using the flat end of the spudger.
    Chiedi a FixBot
    Aggiungi Commento
  10. HTC One Mini 2 Battery Replacement: passo 10, immagine 1 di 3 HTC One Mini 2 Battery Replacement: passo 10, immagine 2 di 3 HTC One Mini 2 Battery Replacement: passo 10, immagine 3 di 3
    • Use the pointed end of the spudger to pop off the four antenna connectors. Three are located on the top left corner of the motherboard and one on the bottom right.
    Chiedi a FixBot
    Aggiungi Commento
  11. HTC One Mini 2 Battery Replacement: passo 11, immagine 1 di 2 HTC One Mini 2 Battery Replacement: passo 11, immagine 2 di 2
    • Using the pointed end of the spudger, pull the wires for the rumble motor to the left to pull the connector out of the board.
    • The connector is very small and easy to break so take caution when pulling it out. Wiggling the wires as you pull to the left helps.
    Chiedi a FixBot
    Aggiungi Commento
  12. HTC One Mini 2 Battery Replacement: passo 12, immagine 1 di 3 HTC One Mini 2 Battery Replacement: passo 12, immagine 2 di 3 HTC One Mini 2 Battery Replacement: passo 12, immagine 3 di 3
    • Using a T5 torx screwdriver, remove four 2mm screws from the four corners of the motherboard.
    • Once the screws are removed, carefully pull the copper plated motherboard out.
    Chiedi a FixBot
    Aggiungi Commento
  13. HTC One Mini 2 Battery Replacement, Battery: passo 13, immagine 1 di 3 HTC One Mini 2 Battery Replacement, Battery: passo 13, immagine 2 di 3 HTC One Mini 2 Battery Replacement, Battery: passo 13, immagine 3 di 3
    • Use the narrow plastic pry tool to pop off the two ribbon cable connectors located at the bottom of the upper circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  14. HTC One Mini 2 Battery Replacement: passo 14, immagine 1 di 1
    • Use a prying motion on each side of the battery with the narrow plastic pry tool to lift the battery from the frame and remove it.
    • There is an adhesive under the battery. This may take some extra work to pry off.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 23 persone hanno completato questa guida.
Cal Poly, Team 4-48, Amido Fall 2014 Membro di Cal Poly, Team 4-48, Amido Fall 2014
CPSU-AMIDO-F14S4G48
5 Membri
17 guide realizzate
3Commenti sulla guida
I just went through this with my phone and got it all back together, but I just plugged it in to charge and the screen just shows a gray blob slowly getting darker until the LED charging light shuts off and the screen goes blank. I don’t know if maybe I missed connecting something or what. Any suggestions on what may be unplugged/damaged?
Anthony - Rispondi Condividi
Same here, Anthony. Did you ever resolve grey blob problem?
Don - Rispondi Condividi
funny I got the same problem, the charge light stays on and if you press vol dn and power button at same time it buzzes after 5 seconds
gordon beaton - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 39
Tutti i Tempi: 43,092
