Salta al contenuto principale
HTC MyTouch 4G Button Replacement
Cosa ti serve
  1. HTC MyTouch 4G Button Replacement, Flip Phone Over: passo 1, immagine 1 di 1
    • Flip your phone over and hold the phone with the back facing you.
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC MyTouch 4G Button Replacement, Remove the back case.: passo 2, immagine 1 di 1
    • Place the prying tool into the notch at the bottom of the case and pull up to remove.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC MyTouch 4G Button Replacement, Remove the battery: passo 3, immagine 1 di 2 HTC MyTouch 4G Button Replacement, Remove the battery: passo 3, immagine 2 di 2
    • Use the plastic prying tool in the upper left-hand corner notch of the battery to remove.
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC MyTouch 4G Button Replacement, Removing Screws: passo 4, immagine 1 di 1
    • Remove the two T5x5mm Screws with the T5 Torx Screw driver.
    • Remove the one Phillips screw with the Phillips #00 Screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  5. HTC MyTouch 4G Button Replacement, Removing back case.: passo 5, immagine 1 di 3 HTC MyTouch 4G Button Replacement, Removing back case.: passo 5, immagine 2 di 3 HTC MyTouch 4G Button Replacement, Removing back case.: passo 5, immagine 3 di 3
    • Use the plastic opening tools to remove the back case.
    • There are four T5x5mm screws. Use the T5 Torx Screwdriver to remove them.
    • Using the plastic opening tools, remove the Wifi antenna.
    Chiedi a FixBot
    Aggiungi Commento
  6. HTC MyTouch 4G Button Replacement, Removing four T5 Screws: passo 6, immagine 1 di 2 HTC MyTouch 4G Button Replacement, Removing four T5 Screws: passo 6, immagine 2 di 2
    • There are three button ribbons on the phone that need to be pulled down off of the case.
    • With the plastic opening tools, pull the button ribbons down away from the frame without completely removing them.
    Chiedi a FixBot
    Aggiungi Commento
  7. HTC MyTouch 4G Button Replacement: passo 7, immagine 1 di 3 HTC MyTouch 4G Button Replacement: passo 7, immagine 2 di 3 HTC MyTouch 4G Button Replacement: passo 7, immagine 3 di 3
    • After making sure the button ribbons are away from the frame, insert the plastic opening tool into the frame and remove it.
    • Remove two Philips screws holding the Motherboard in place.
    Chiedi a FixBot
    Aggiungi Commento
  8. HTC MyTouch 4G Button Replacement: passo 8, immagine 1 di 2 HTC MyTouch 4G Button Replacement: passo 8, immagine 2 di 2
    • Three ribbon cables and the vibration motor need to be disconnected from the motherboard.
    • Using the plastic opening tools, pull up on the power button ribbon to gently detach it.
    • Remove the vibration motor by gently pulling it off of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  9. HTC MyTouch 4G Button Replacement: passo 9, immagine 1 di 3 HTC MyTouch 4G Button Replacement: passo 9, immagine 2 di 3 HTC MyTouch 4G Button Replacement: passo 9, immagine 3 di 3
    • Remove the digitizer ribbon cable with the plastic opening tools.
    • Remove the LCD ribon cable from its connector.
    • It is now safe to release the Motherboard from the clips holding it in place. Start at the top clip of the phone and move your way around gently releasing each clip.
    Chiedi a FixBot
    Aggiungi Commento
  10. HTC MyTouch 4G Button Replacement: passo 10, immagine 1 di 3 HTC MyTouch 4G Button Replacement: passo 10, immagine 2 di 3 HTC MyTouch 4G Button Replacement: passo 10, immagine 3 di 3
    • Do not lift the Motherboard off the phone. The LCD Ribbon is still connected to it.
    • Lift the Motherboard towards the left to expose the LCD clamp connector.
    • Open the clamp connector of the LCD ribbon by carefully pulling it up with the plastic opening tools.
    Chiedi a FixBot
    Aggiungi Commento
  11. HTC MyTouch 4G Button Replacement: passo 11, immagine 1 di 1
    • The motherboard is now removed.
    Chiedi a FixBot
    Aggiungi Commento
  12. HTC MyTouch 4G Button Replacement, Button: passo 12, immagine 1 di 2 HTC MyTouch 4G Button Replacement, Button: passo 12, immagine 2 di 2
    • After removing the motherboard from the phone, the button bar is exposed and easily replaced.
    • Use the plastic opening tools to remove the button bar and replace it with the new one.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Braden
Membro da: 01/30/15
425 Reputazione
2 guide realizzate
USF Tampa, Team 16-5, Watkins Spring 2014 Membro di USF Tampa, Team 16-5, Watkins Spring 2014
USFT-WATKINS-S14S16G5
2 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 27
Tutti i Tempi: 675
