Salta al contenuto principale
HTC Hero Touch Screen Digitizer Replacement
Cosa ti serve
  1. HTC Hero Touch Screen Digitizer Replacement, Back Case: passo 1, immagine 1 di 1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC Hero Touch Screen Digitizer Replacement: passo 2, immagine 1 di 1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC Hero Touch Screen Digitizer Replacement: passo 3, immagine 1 di 1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC Hero Touch Screen Digitizer Replacement: passo 4, immagine 1 di 2 HTC Hero Touch Screen Digitizer Replacement: passo 4, immagine 2 di 2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    Chiedi a FixBot
    Aggiungi Commento
  5. HTC Hero Touch Screen Digitizer Replacement, Touch Screen: passo 5, immagine 1 di 2 HTC Hero Touch Screen Digitizer Replacement, Touch Screen: passo 5, immagine 2 di 2
    • Gently release the two ribbon cables using a plastic opening tool by prying up the pop connectors used to attach the ribbon cables to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. HTC Hero Touch Screen Digitizer Replacement: passo 6, immagine 1 di 2 HTC Hero Touch Screen Digitizer Replacement: passo 6, immagine 2 di 2
    • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  7. HTC Hero Touch Screen Digitizer Replacement: passo 7, immagine 1 di 2 HTC Hero Touch Screen Digitizer Replacement: passo 7, immagine 2 di 2
    • Gently lift the motherboard out of the front enclosure once the screws are removed.
    Chiedi a FixBot
    Aggiungi Commento
  8. HTC Hero Touch Screen Digitizer Replacement: passo 8, immagine 1 di 3 HTC Hero Touch Screen Digitizer Replacement: passo 8, immagine 2 di 3 HTC Hero Touch Screen Digitizer Replacement: passo 8, immagine 3 di 3
    • Remove the trackball and its enclosure by turning the phone over into your cupped hand and allowing the trackball and enclosure to fall out.
    Chiedi a FixBot
    Aggiungi Commento
  9. HTC Hero Touch Screen Digitizer Replacement: passo 9, immagine 1 di 3 HTC Hero Touch Screen Digitizer Replacement: passo 9, immagine 2 di 3 HTC Hero Touch Screen Digitizer Replacement: passo 9, immagine 3 di 3
    • Gently pry out the LCD screen from the top left side of the enclosure using a plastic tool, as illustrated.
    Chiedi a FixBot
    Aggiungi Commento
  10. HTC Hero Touch Screen Digitizer Replacement: passo 10, immagine 1 di 2 HTC Hero Touch Screen Digitizer Replacement: passo 10, immagine 2 di 2
    • Using a plastic opening tool, gently pry the glass from the frame by inserting the flat end between the glass and the frame from the inside of the phone.
    • Follow the edges of the glass to ensure that all the adhesive has been released.
    Chiedi a FixBot
    Aggiungi Commento
  11. HTC Hero Touch Screen Digitizer Replacement: passo 11, immagine 1 di 1
    • Using a heat lamp or gun, warm the glass to loosen the adhesive binding it to the frame.
    • Once the adhesive has been released, you should be able to remove the glass by pushing on it from the inside of the phone.
    • Be careful to remove the glass slowly. The ribbon cable that connects to the glass is routed through the plastic frame at the bottom.
    Chiedi a FixBot
    Aggiungi Commento
  12. HTC Hero Touch Screen Digitizer Replacement: passo 12, immagine 1 di 3 HTC Hero Touch Screen Digitizer Replacement: passo 12, immagine 2 di 3 HTC Hero Touch Screen Digitizer Replacement: passo 12, immagine 3 di 3
    • Carefully feed the ribbon cable through the slot in the plastic frame.
    Chiedi a FixBot
    Aggiungi Commento
  13. HTC Hero Touch Screen Digitizer Replacement: passo 13, immagine 1 di 1
    • Remove any excess adhesive from the plastic frame.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Max Brown
Membro da: 01/23/12
139 Reputazione
4 guide realizzate
Cal Poly, Team 3-26, Amido Winter 2012 Membro di Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 32
Tutti i Tempi: 3,824
