Salta al contenuto principale
HTC Hero Camera Replacement
Cosa ti serve
  1. HTC Hero Camera Replacement, Back Case: passo 1, immagine 1 di 1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC Hero Camera Replacement: passo 2, immagine 1 di 1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC Hero Camera Replacement: passo 3, immagine 1 di 1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC Hero Camera Replacement: passo 4, immagine 1 di 2 HTC Hero Camera Replacement: passo 4, immagine 2 di 2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    Chiedi a FixBot
    Aggiungi Commento
  5. HTC Hero Camera Replacement, Camera: passo 5, immagine 1 di 3 HTC Hero Camera Replacement, Camera: passo 5, immagine 2 di 3 HTC Hero Camera Replacement, Camera: passo 5, immagine 3 di 3
    • Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. HTC Hero Camera Replacement: passo 6, immagine 1 di 2 HTC Hero Camera Replacement: passo 6, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Using a pair of metal tweezers, simultaneously depress both tabs on one side of the camera enclosure and gently pull up until tabs come free. Repeat for the opposite side.
    Chiedi a FixBot
    Aggiungi Commento
  7. HTC Hero Camera Replacement: passo 7, immagine 1 di 2 HTC Hero Camera Replacement: passo 7, immagine 2 di 2
    • Pull the released camera enclosure away from the motherboard until it is completely free.
    Chiedi a FixBot
    Aggiungi Commento
  8. HTC Hero Camera Replacement: passo 8, immagine 1 di 2 HTC Hero Camera Replacement: passo 8, immagine 2 di 2
    • Now with camera unit exposed, gently wiggle the camera as you pull away from the phone to remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Max Brown
Membro da: 01/23/12
139 Reputazione
4 guide realizzate
Cal Poly, Team 3-26, Amido Winter 2012 Membro di Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 36
Tutti i Tempi: 1,692
