Salta al contenuto principale
HTC HD2 Camera Replacement
Cosa ti serve
  1. HTC HD2 Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC HD2 Camera Replacement: passo 2, immagine 1 di 2 HTC HD2 Camera Replacement: passo 2, immagine 2 di 2
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC HD2 Camera Replacement, Midframe: passo 3, immagine 1 di 2 HTC HD2 Camera Replacement, Midframe: passo 3, immagine 2 di 2
    • Remove the four black 3.5mm T5 screws from the back of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC HD2 Camera Replacement: passo 4, immagine 1 di 2 HTC HD2 Camera Replacement: passo 4, immagine 2 di 2
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
    Chiedi a FixBot
    Aggiungi Commento
  5. HTC HD2 Camera Replacement, Camera: passo 5, immagine 1 di 3 HTC HD2 Camera Replacement, Camera: passo 5, immagine 2 di 3 HTC HD2 Camera Replacement, Camera: passo 5, immagine 3 di 3
    • Disconnect the flash cable from its socket in the bottom of the motherboard.
    • Carefully pull the cable from its groove in the frame, working your way back to the camera.
    Chiedi a FixBot
    Aggiungi Commento
  6. HTC HD2 Camera Replacement: passo 6, immagine 1 di 3 HTC HD2 Camera Replacement: passo 6, immagine 2 di 3 HTC HD2 Camera Replacement: passo 6, immagine 3 di 3
    • Pull the camera flash and cover off of the board.
    • You may need to peel back the sticker that sits behind the battery.
    • Work carefully. Excessive force can damage the camera or motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. HTC HD2 Camera Replacement: passo 7, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Around the camera is a thin shielding. Remove it with tweezers.
    • Using tweezers, remove the primary camera.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 24-55, Amido Spring 2011 Membro di Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Membri
24 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 46
Tutti i Tempi: 8,405
