Salta al contenuto principale
HTC Excalibur Screen Replacement
Cosa ti serve
  1. HTC Excalibur Screen Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove the rubber screw covers. If needed, use a thin object to help pry them off. There should be two of them on top of the phone. Skip this step if already removed.
    • Pry loose the metal cover near the camera lens.
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC Excalibur Screen Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover.
    • Gripping the battery by the bottom, lift and remove it from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC Excalibur Screen Replacement: passo 3, immagine 1 di 3 HTC Excalibur Screen Replacement: passo 3, immagine 2 di 3 HTC Excalibur Screen Replacement: passo 3, immagine 3 di 3
    • After removing the rubber stoppers on top, there should be six exposed screws. Remove these using the T6 screwdriver.
    • Next, use the spudger to loosen the case underneath the shiny metal edge. Go all the way around the phone until completely loosened.
    • The case is superglued on and will not permanently damage the phone when removed, but you should still use caution.
    • After loosening the case, remove it.
    • There is a wire that connects both the top and bottom of the case. If you are not careful when removing the case, you might snap the wire.
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC Excalibur Screen Replacement: passo 4, immagine 1 di 2 HTC Excalibur Screen Replacement: passo 4, immagine 2 di 2
    • Remove the one remaining screw in the logic board.
    • Unclip the wire that connects the back of the case to the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  5. HTC Excalibur Screen Replacement: passo 5, immagine 1 di 3 HTC Excalibur Screen Replacement: passo 5, immagine 2 di 3 HTC Excalibur Screen Replacement: passo 5, immagine 3 di 3
    • On the left side of the phone, there are three copper colored clips.
    • Unclip the bottom clip, thread the middle one through the logic board, and pull the top one out gently.
    • You can then lift the logic board out of the phone.
    • Do this at an angle, lifting the side to the right of the SIM card instructions.
    • One of the strips is attached to the front of the case, and goes through the logic board. Be careful not to break this piece.
    Chiedi a FixBot
    Aggiungi Commento
  6. HTC Excalibur Screen Replacement, Screen: passo 6, immagine 1 di 1
    • Remove the metal frame. Slip out the copper clips still attached to the bottom frame from the frame carefully.
    Chiedi a FixBot
    Aggiungi Commento
  7. HTC Excalibur Screen Replacement: passo 7, immagine 1 di 1
    • Grab the screen by the bottom edge, and lift it out at an angle.
    • Replace the screen, and reassemble the phone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 25-27, Garner Spring 2011 Membro di Cal Poly, Team 25-27, Garner Spring 2011
CPSU-GARNER-S11S25G27
4 Membri
20 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 11
Ultimi 30 giorni: 37
Tutti i Tempi: 2,163
