Salta al contenuto principale
HTC Droid DNA Micro USB Port Replacement
Cosa ti serve
  1. HTC Droid DNA Micro USB Port Replacement, Remove the SIM Card Tray: passo 1, immagine 1 di 1
    • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
    Chiedi a FixBot
    Aggiungi Commento
  2. HTC Droid DNA Micro USB Port Replacement, Removing the SIM Card Tray: passo 2, immagine 1 di 2 HTC Droid DNA Micro USB Port Replacement, Removing the SIM Card Tray: passo 2, immagine 2 di 2
    • Pull out the SIM Card Tray with your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  3. HTC Droid DNA Micro USB Port Replacement, Loosen the Phone Casing: passo 3, immagine 1 di 2 HTC Droid DNA Micro USB Port Replacement, Loosen the Phone Casing: passo 3, immagine 2 di 2
    • Make sure the USB cover on the bottom of the phone is removed first.
    • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
    • Take your time. A lot of force is necessary to loosen the front panel.
    Chiedi a FixBot
    Aggiungi Commento
  4. HTC Droid DNA Micro USB Port Replacement, Pull the Casing Apart: passo 4, immagine 1 di 1
    • Slowly pull the panel apart from the back of the phone.
    • Apply a moderate force to pry the panel from the back of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  5. HTC Droid DNA Micro USB Port Replacement, Remove the Black Tape: passo 5, immagine 1 di 1
    • Set the device down so that the bottom of the phone is facing to the right.
    • Gently take off the piece of black tape surrounding the motherboard.
    • Be careful not to rip the tape.
    Chiedi a FixBot
    Aggiungi Commento
  6. HTC Droid DNA Micro USB Port Replacement, Remove the Yellow Tape: passo 6, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  7. HTC Droid DNA Micro USB Port Replacement: passo 7, immagine 1 di 1
    • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
    • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  8. HTC Droid DNA Micro USB Port Replacement, Remove the Void Screw: passo 8, immagine 1 di 1
    • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
    Chiedi a FixBot
    Aggiungi Commento
  9. HTC Droid DNA Micro USB Port Replacement, Remove the Screw Retaining Bracket: passo 9, immagine 1 di 1
    • Rotate your phone back 90 Degrees counter-clockwise.
    • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  10. HTC Droid DNA Micro USB Port Replacement, Remove the Connector Screws: passo 10, immagine 1 di 1
    • Remove the following Phillips #000 screws from the motherboard:
    • Four 1.6 mm screws
    • Two 1.5 mm screws
    Chiedi a FixBot
    Aggiungi Commento
  11. HTC Droid DNA Micro USB Port Replacement, Unfasten the Connectors: passo 11, immagine 1 di 2 HTC Droid DNA Micro USB Port Replacement, Unfasten the Connectors: passo 11, immagine 2 di 2
    • Use your pry tool to unfasten the connectors on both sides of the motherboard.
    • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
    Chiedi a FixBot
    Aggiungi Commento
  12. HTC Droid DNA Micro USB Port Replacement, Remove the Yellow Tape: passo 12, immagine 1 di 1
    • Use your tweezers to remove the two pieces of yellow tape shown.
    Chiedi a FixBot
    Aggiungi Commento
  13. HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: passo 13, immagine 1 di 2 HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: passo 13, immagine 2 di 2
    • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  14. HTC Droid DNA Micro USB Port Replacement, Disconnect the Connector: passo 14, immagine 1 di 1
    • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cable of the Connector.
    Chiedi a FixBot
    Aggiungi Commento
  15. HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: passo 15, immagine 1 di 2 HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: passo 15, immagine 2 di 2
    • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
    Chiedi a FixBot
    Aggiungi Commento
  16. HTC Droid DNA Micro USB Port Replacement, Disconnect the Connector: passo 16, immagine 1 di 1
    • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cables for the Connector.
    Chiedi a FixBot
    Aggiungi Commento
  17. HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: passo 17, immagine 1 di 2 HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: passo 17, immagine 2 di 2
    • Rotate the phone 180 degrees.
    • Use your tweezers to gently snap up the white board on the top left of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  18. HTC Droid DNA Micro USB Port Replacement, Disconnect the Connector: passo 18, immagine 1 di 1
    • Use your tweezers to disconnect the cable on the top left of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  19. HTC Droid DNA Micro USB Port Replacement, Flipping up the Black Board: passo 19, immagine 1 di 2 HTC Droid DNA Micro USB Port Replacement, Flipping up the Black Board: passo 19, immagine 2 di 2
    • Use your tweezers to gently snap up the black board on the top left of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  20. HTC Droid DNA Micro USB Port Replacement, Disconnect the Small Ribbon Connector: passo 20, immagine 1 di 1
    • Use your tweezers to gently remove the yellow connector on the top left of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  21. HTC Droid DNA Micro USB Port Replacement, Remove the Black Wire: passo 21, immagine 1 di 1
    • Remove the long black wire on the left of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  22. HTC Droid DNA Micro USB Port Replacement, Remove the Two Black Wires: passo 22, immagine 1 di 1
    • Reorient the phone so that the green camera board is farthest from you.
    • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
    Chiedi a FixBot
    Aggiungi Commento
  23. HTC Droid DNA Micro USB Port Replacement, Remove the Screws: passo 23, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  24. HTC Droid DNA Micro USB Port Replacement, Remove the Motherboard: passo 24, immagine 1 di 2 HTC Droid DNA Micro USB Port Replacement, Remove the Motherboard: passo 24, immagine 2 di 2
    • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  25. HTC Droid DNA Micro USB Port Replacement, Remove the Charging Port Assembly: passo 25, immagine 1 di 2 HTC Droid DNA Micro USB Port Replacement, Remove the Charging Port Assembly: passo 25, immagine 2 di 2
    • Use the plastic prying tool to gently remove the charging port assembly.
    Chiedi a FixBot
    Aggiungi Commento
  26. HTC Droid DNA Micro USB Port Replacement, Disassemble Charging Port Assembly: passo 26, immagine 1 di 1
    • Use a Phillips #000 screw driver to remove the single 2.1mm screw located on the backside of the assembly.
    Chiedi a FixBot
    Aggiungi Commento
  27. HTC Droid DNA Micro USB Port Replacement, Undo the Wire Connection: passo 27, immagine 1 di 2 HTC Droid DNA Micro USB Port Replacement, Undo the Wire Connection: passo 27, immagine 2 di 2
    • Use your tweezers to undo the red and black wire connection.
    Chiedi a FixBot
    Aggiungi Commento
  28. HTC Droid DNA Micro USB Port Replacement, Separate the Black and Blue Assembly Pieces: passo 28, immagine 1 di 3 HTC Droid DNA Micro USB Port Replacement, Separate the Black and Blue Assembly Pieces: passo 28, immagine 2 di 3 HTC Droid DNA Micro USB Port Replacement, Separate the Black and Blue Assembly Pieces: passo 28, immagine 3 di 3
    • Use the plastic prying tool to separate the assembly into two pieces: blue and black.
    Chiedi a FixBot
    Aggiungi Commento
  29. HTC Droid DNA Micro USB Port Replacement, Remove the wire: passo 29, immagine 1 di 2 HTC Droid DNA Micro USB Port Replacement, Remove the wire: passo 29, immagine 2 di 2
    • Remove the black wire on the blue piece (the Micro USB charging port) so it is out of the way and cannot get damaged.
    • If the micro USB port is damaged, the charging port may need to be replaced.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 4-43, Amido Fall 2014 Membro di Cal Poly, Team 4-43, Amido Fall 2014
CPSU-AMIDO-F14S4G43
4 Membri
19 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 4
Ultimi 30 giorni: 35
Tutti i Tempi: 2,776
