Salta al contenuto principale
HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement
Cosa ti serve
    1. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: passo 1, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: passo 1, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: passo 1, immagine 3 di 3
      • Slide the rear compartment cover in the direction of the arrow.
      • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
      Chiedi a FixBot
      Aggiungi Commento
    1. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Shell: passo 2, immagine 1 di 2 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Shell: passo 2, immagine 2 di 2
      • Remove the four 4mm screws using a Phillips #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: passo 3, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: passo 3, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: passo 3, immagine 3 di 3
      • Grip the main body and pull the joystick outwards until the entire front panel pops off.
      • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: passo 4, immagine 1 di 2 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: passo 4, immagine 2 di 2
      • Use a spudger to pry apart the two halves of the assembly.
      • Work slowly, prying a small section at a time until the halves are completely separated.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team S18-G5, White Winter 2019 Membro di Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Membri
26 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 26
Tutti i Tempi: 1,212
