Introduzione
Are you finding that your laptop's battery life isn't lasting as long as it first was? It might be time to consider replacing the battery to restore those lengthy work or entertainment sessions without constant interruptions. Typically, after 18 to 24 months of frequent use, laptop batteries tend to show signs of wear and diminished performance, prompting for the need for replacement.
In this guide, we'll walk you through the steps to safely remove and reinstall your laptop's battery. Whether you're looking to replace a worn-out battery or simply need to access other components within your laptop, this process is essential. Before diving in, it's important to gather the necessary tools, so please have ready a plastic prying tool and a Phillips #1 screwdriver head.
Let's get started.
Cosa ti serve
Use an opening pick to gently pry up the edge of the rubber foot.
Grab the lifted edge of the foot and gently pull it away.
Repeat for the other rubber foot.
Remove the following Phillips screws that secure the battery:
Three 2.9 mm
Two 6.8 mm
For optimal performance, calibrate your newly installed battery after completing this guide.
Altre 2 persone hanno completato questa guida.
