Salta al contenuto principale
HP Stream 11-d010nr Clickpad Replacement
Cosa ti serve
  1. HP Stream 11-d010nr Clickpad Replacement, Pry out the inserts: passo 1, immagine 1 di 2 HP Stream 11-d010nr Clickpad Replacement, Pry out the inserts: passo 1, immagine 2 di 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP Stream 11-d010nr Clickpad Replacement, Unscrew the back cover: passo 2, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP Stream 11-d010nr Clickpad Replacement, Pry the keyboard casing up: passo 3, immagine 1 di 2 HP Stream 11-d010nr Clickpad Replacement, Pry the keyboard casing up: passo 3, immagine 2 di 2
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP Stream 11-d010nr Clickpad Replacement, Identify the connectors: passo 4, immagine 1 di 1
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP Stream 11-d010nr Clickpad Replacement, Disconnect the cables: passo 5, immagine 1 di 3 HP Stream 11-d010nr Clickpad Replacement, Disconnect the cables: passo 5, immagine 2 di 3 HP Stream 11-d010nr Clickpad Replacement, Disconnect the cables: passo 5, immagine 3 di 3
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP Stream 11-d010nr Clickpad Replacement, Lift the keyboard out: passo 6, immagine 1 di 1
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP Stream 11-d010nr Clickpad Replacement, Clickpad: passo 7, immagine 1 di 2 HP Stream 11-d010nr Clickpad Replacement, Clickpad: passo 7, immagine 2 di 2
    • Remove the two 2mm #000 Phillips screws.
    Chiedi a FixBot
    Aggiungi Commento
  8. HP Stream 11-d010nr Clickpad Replacement: passo 8, immagine 1 di 1
    • Release the clickpad by lifting the keyboard up.
    • When installing the new clickpad, make sure the black tabs go into the laptop.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team S1-G3, White Winter 2019 Membro di Cal Poly, Team S1-G3, White Winter 2019
CPSU-WHITE-W19S1G3
4 Membri
11 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 5
Ultimi 30 giorni: 24
Tutti i Tempi: 594
