Salta al contenuto principale
HP ProBook 455 G7 Fan Replacement
Cosa ti serve
  1. HP ProBook 455 G7 Fan Replacement, Lower Case: passo 1, immagine 1 di 1
    • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
    • Flip the laptop over so the lower case is facing up.
    • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
    Chiedi a FixBot
  2. HP ProBook 455 G7 Fan Replacement: passo 2, immagine 1 di 3 HP ProBook 455 G7 Fan Replacement: passo 2, immagine 2 di 3 HP ProBook 455 G7 Fan Replacement: passo 2, immagine 3 di 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Lift and remove the lower case.
    Chiedi a FixBot
  3. HP ProBook 455 G7 Fan Replacement, Battery: passo 3, immagine 1 di 3 HP ProBook 455 G7 Fan Replacement, Battery: passo 3, immagine 2 di 3 HP ProBook 455 G7 Fan Replacement, Battery: passo 3, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
    • Carefully lift the battery and remove it from the laptop.
    Chiedi a FixBot
  4. HP ProBook 455 G7 Fan Replacement, Fan: passo 4, immagine 1 di 2 HP ProBook 455 G7 Fan Replacement, Fan: passo 4, immagine 2 di 2
    • Remove the three 4 mm-long Phillips #1 screws securing the fan.
    Chiedi a FixBot
  5. HP ProBook 455 G7 Fan Replacement: passo 5, immagine 1 di 2 HP ProBook 455 G7 Fan Replacement: passo 5, immagine 2 di 2
    • Gently unplug the fan power cable from the motherboard connector using tweezers or your fingers.
    • Lift the fan up and out to remove it.
    Chiedi a FixBot
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
UMass Dartmouth, Team 1-6, Botvin Fall 2025 Membro di UMass Dartmouth, Team 1-6, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G6
3 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 24
Tutti i Tempi: 96
