Salta al contenuto principale
HP ProBook 4520s Keyboard Replacement
Cosa ti serve
  1. HP ProBook 4520s Keyboard Replacement, Battery: passo 1, immagine 1 di 2 HP ProBook 4520s Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP ProBook 4520s Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the battery by holding the latches and sliding the battery away from you.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP ProBook 4520s Keyboard Replacement, Switch Cover: passo 3, immagine 1 di 2 HP ProBook 4520s Keyboard Replacement, Switch Cover: passo 3, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP ProBook 4520s Keyboard Replacement: passo 4, immagine 1 di 2 HP ProBook 4520s Keyboard Replacement: passo 4, immagine 2 di 2
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP ProBook 4520s Keyboard Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP ProBook 4520s Keyboard Replacement: passo 6, immagine 1 di 3 HP ProBook 4520s Keyboard Replacement: passo 6, immagine 2 di 3 HP ProBook 4520s Keyboard Replacement: passo 6, immagine 3 di 3
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP ProBook 4520s Keyboard Replacement, Keyboard: passo 7, immagine 1 di 2 HP ProBook 4520s Keyboard Replacement, Keyboard: passo 7, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
    Chiedi a FixBot
    Aggiungi Commento
  8. HP ProBook 4520s Keyboard Replacement: passo 8, immagine 1 di 1
    • Slide the keyboard panel away from you to free it from the 4520s.
    • Do not yank the keyboard panel away from the 4520s. This may damage the cable.
    Chiedi a FixBot
    Aggiungi Commento
  9. HP ProBook 4520s Keyboard Replacement: passo 9, immagine 1 di 2 HP ProBook 4520s Keyboard Replacement: passo 9, immagine 2 di 2
    • Gently raise up the keyboard and flip it over to reveal a ribbon cable.
    • Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
    • Remove the cable and lift the keyboard panel up. Set it aside.
    • When reassembling, feed the ribbon cable into the port. Press down on the tab to pinch the cable in place.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these steps in reverse order.
Altre 7 persone hanno completato questa guida.
UC Davis, Team 1-3, Oliver Fall 2016 Membro di UC Davis, Team 1-3, Oliver Fall 2016
UCD-OLIVER-F16S1G3
5 Membri
8 guide realizzate
1Commento della guida
hp probook 4520s disassembly
https://youtu.be/8749zmz0lls
mohamed - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 41
Tutti i Tempi: 5,278
