Salta al contenuto principale
HP ProBook 4320t Touchpad Panel Replacement Guide
Cosa ti serve
  1. HP ProBook 4320t Touchpad Panel Replacement Guide, Battery Removal: passo 1, immagine 1 di 2 HP ProBook 4320t Touchpad Panel Replacement Guide, Battery Removal: passo 1, immagine 2 di 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP ProBook 4320t Touchpad Panel Replacement Guide, Screws: passo 2, immagine 1 di 2 HP ProBook 4320t Touchpad Panel Replacement Guide, Screws: passo 2, immagine 2 di 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
    Chiedi a FixBot
    Aggiungi Commento
  3. HP ProBook 4320t Touchpad Panel Replacement Guide, Flip: passo 3, immagine 1 di 1
    • Flip laptop over and open it.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP ProBook 4320t Touchpad Panel Replacement Guide, Push N Lift: passo 4, immagine 1 di 1
    • Slightly push up while lifting up on the power button panel to release the panel.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP ProBook 4320t Touchpad Panel Replacement Guide, Unscrewing: passo 5, immagine 1 di 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
    Chiedi a FixBot
    Aggiungi Commento
  6. HP ProBook 4320t Touchpad Panel Replacement Guide, Careful Now: passo 6, immagine 1 di 2 HP ProBook 4320t Touchpad Panel Replacement Guide, Careful Now: passo 6, immagine 2 di 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP ProBook 4320t Touchpad Panel Replacement Guide, Disconnect Wire: passo 7, immagine 1 di 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  8. HP ProBook 4320t Touchpad Panel Replacement Guide, Unscrew: passo 8, immagine 1 di 1
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
    Chiedi a FixBot
    Aggiungi Commento
  9. HP ProBook 4320t Touchpad Panel Replacement Guide, Slide the Panel Off: passo 9, immagine 1 di 1
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
    Chiedi a FixBot
    Aggiungi Commento
  10. HP ProBook 4320t Touchpad Panel Replacement Guide, Lift up Carefully: passo 10, immagine 1 di 1
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
    Chiedi a FixBot
    Aggiungi Commento
  11. HP ProBook 4320t Touchpad Panel Replacement Guide, Disconnect Wire: passo 11, immagine 1 di 1
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Joshua
Membro da: 09/23/14
134 Reputazione
6 guide realizzate
USF Tampa, Team 9-5, Blackwell Fall 2014 Membro di USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 25
Tutti i Tempi: 630
