Salta al contenuto principale
HP ProBook 4320t Keyboard Replacement Guide
Cosa ti serve
  1. HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: passo 1, immagine 1 di 2 HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: passo 1, immagine 2 di 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP ProBook 4320t Keyboard Replacement Guide, Screws: passo 2, immagine 1 di 2 HP ProBook 4320t Keyboard Replacement Guide, Screws: passo 2, immagine 2 di 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
    Chiedi a FixBot
    Aggiungi Commento
  3. HP ProBook 4320t Keyboard Replacement Guide, Flip: passo 3, immagine 1 di 1
    • Flip laptop over and open it.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP ProBook 4320t Keyboard Replacement Guide, Push N Lift: passo 4, immagine 1 di 1
    • Slightly push up while lifting up on the power button panel to release the panel.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP ProBook 4320t Keyboard Replacement Guide, Unscrewing: passo 5, immagine 1 di 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
    Chiedi a FixBot
    Aggiungi Commento
  6. HP ProBook 4320t Keyboard Replacement Guide, Careful Now: passo 6, immagine 1 di 2 HP ProBook 4320t Keyboard Replacement Guide, Careful Now: passo 6, immagine 2 di 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP ProBook 4320t Keyboard Replacement Guide, Disconnect Wire: passo 7, immagine 1 di 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Joshua
Membro da: 09/23/14
134 Reputazione
6 guide realizzate
USF Tampa, Team 9-5, Blackwell Fall 2014 Membro di USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 23
Tutti i Tempi: 1,245
