Salta al contenuto principale
HP Pavilion N3350 RAM Replacement
Cosa ti serve
  1. HP Pavilion N3350 RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Locate the RAM on the bottom side of the laptop, the cover is secured by a 6 millimeter screw. Remove this with a Philips #1 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP Pavilion N3350 RAM Replacement: passo 2, immagine 1 di 1
    • Underneath are the RAM boards. They are secured by two plastic clips each. Locate these to continue removal.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP Pavilion N3350 RAM Replacement: passo 3, immagine 1 di 1
    • Place your thumbs on two of the clips securing one board. Push outwards on the clips. This should pop the board up.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP Pavilion N3350 RAM Replacement: passo 4, immagine 1 di 1
    • Repeat on second board. When both are released, they should appear as they do in the picture.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP Pavilion N3350 RAM Replacement: passo 5, immagine 1 di 1
    • The RAM should be easily removed once released from the plastic clips.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
1Commento della guida
Windows 98 Product Key?
Dudefoxlive - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 34
Tutti i Tempi: 433
