Salta al contenuto principale
HP Pavilion G60-630US RAM Replacement
Cosa ti serve
  1. HP Pavilion G60-630US  RAM Replacement, Battery: passo 1, immagine 1 di 3 HP Pavilion G60-630US  RAM Replacement, Battery: passo 1, immagine 2 di 3 HP Pavilion G60-630US  RAM Replacement, Battery: passo 1, immagine 3 di 3
    • Make sure the laptop is powered off and unplugged first.
    • Turn your laptop over so the bottom is facing up.
    • Locate the battery latch and slide the latch switch all the way to the left.
    • The latch will lock and stay in place.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP Pavilion G60-630US  RAM Replacement: passo 2, immagine 1 di 3 HP Pavilion G60-630US  RAM Replacement: passo 2, immagine 2 di 3 HP Pavilion G60-630US  RAM Replacement: passo 2, immagine 3 di 3
    • Carefully lift the battery out and away from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP Pavilion G60-630US  RAM Replacement, RAM: passo 3, immagine 1 di 2 HP Pavilion G60-630US  RAM Replacement, RAM: passo 3, immagine 2 di 2
    • Remove the two 5.5 mm JIS#0 screws.
    • Lift the panel up and off the computer.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP Pavilion G60-630US  RAM Replacement: passo 4, immagine 1 di 3 HP Pavilion G60-630US  RAM Replacement: passo 4, immagine 2 di 3 HP Pavilion G60-630US  RAM Replacement: passo 4, immagine 3 di 3
    • Once the panel is removed the RAM card will be visible.
    • The RAM is inserted into its socket with some metal triggers. To remove the RAM card, push the triggers away from the RAM card.
    • If done right, the card will be at an upward angle pointing out of the device.
    • Gently grasp the RAM card ,and pull it out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To insert a new RAM card, put the card into the slot and press down till the metal triggers click over it, holding it in place. After that, follow steps 1 to 3 in reverse order.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 34
Tutti i Tempi: 761
