Salta al contenuto principale
HP Pavilion 15-e043cl RAM Replacement
Cosa ti serve
  1. HP Pavilion 15-e043cl RAM Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 15-e043cl RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the device over.
    • Slide the battery switch on the right half of the laptop.
    • Make sure the device is powered off, and that it is not connected to any power sources.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP Pavilion 15-e043cl RAM Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-e043cl RAM Replacement: passo 2, immagine 2 di 2
    • Lift the battery up and out of the device by the inward-facing edge.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP Pavilion 15-e043cl RAM Replacement, Maintenance Panel: passo 3, immagine 1 di 3 HP Pavilion 15-e043cl RAM Replacement, Maintenance Panel: passo 3, immagine 2 di 3 HP Pavilion 15-e043cl RAM Replacement, Maintenance Panel: passo 3, immagine 3 di 3
    • Unscrew the single Phillips #0 captive screw that was previously hidden by the battery.
    • The screw can not, and should not, be fully removed.
    • Slide the maintenance panel away from the battery compartment to release it.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP Pavilion 15-e043cl RAM Replacement, RAM: passo 4, immagine 1 di 2 HP Pavilion 15-e043cl RAM Replacement, RAM: passo 4, immagine 2 di 2
    • Push the two silver arms away from the RAM card.
    • Pull the RAM card out of its slot.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 33
Tutti i Tempi: 391
