Introduzione
Use this guide to replace your keyboard.
There are many possible reasons as to why you may need to replace your keyboard. Before beginning to take apart your computer be sure to check out the troubleshooting guide for possible issues and solutions to your keyboard problems.
Some of the issues that may cause you to replace your keyboard include multiple keys not functioning, messages not appearing on screen, or simply the keyboard is old and faulty.
As always before beginning the tedious task of breaking down the laptop be sure that all power supply is disconnected from the computer.
Cosa ti serve
Turn the laptop over so the back is facing up. Use a Phillips #0 screwdriver to remove the 11 screws from the bottom cover. Rotate the screws counter-clockwise.
Eight 5mm screws.
Three 10mm screws.
Remove the six 5mm screws securing the battery using the Phillips #0 screwdriver.
Gently disconnect the battery from the motherboard with a plastic opening tool and remove it from the device.
Charge it to 100% and continue to charge it for an additional two hours. Next, unplug the charger and use the laptop normally to completely drain the battery. Wait at least five hours and recharge the battery to 100%.
Release the metal tabs on each side of the RAM module by pushing each tab away from the module simultaneously .
Remove the four screws securing the motherboard using the Phillips #0 screwdriver.
