Introduzione
This guide will assist you to replace the battery for the HP Pavilion 15-bk020wm. Be sure you purchased the correct replacement battery before attempting to take the old one out. There is a prerequisite guide to open the bottom of the laptop for easier access. Be sure to power down your device before any disassembly.
Ricambi
Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
Remove the two screw cover strips.
Remove the two screw cover plugs.
Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
Detach the blue ZIF cable from the bottom of the laptop.
Use a plastic opening tool to flip up the two ZIF cables connecting the battery to the motherboard.
Altre 6 persone hanno completato questa guida.
