Salta al contenuto principale
HP Pavilion 14-cf0014dx Battery Replacement
Cosa ti serve
  1. HP Pavilion 14-cf0014dx Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Battery Replacement: passo 2, immagine 1 di 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Battery Replacement: passo 4, immagine 1 di 1
    • Lift the battery up and out and remove it from the device.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Sam Cole
Membro da: 10/25/21
813 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 66
Tutti i Tempi: 1,111
