Salta al contenuto principale
HP OfficeJet 4650 Power Button Replacement
Cosa ti serve
    1. HP OfficeJet 4650 Power Button Replacement, Power Button: passo 1, immagine 1 di 3 HP OfficeJet 4650 Power Button Replacement, Power Button: passo 1, immagine 2 di 3 HP OfficeJet 4650 Power Button Replacement, Power Button: passo 1, immagine 3 di 3
      • Open the cartridge access door by putting one hand on the grooves of each side and pulling up.
      Chiedi a FixBot
      Aggiungi Commento
    2. HP OfficeJet 4650 Power Button Replacement: passo 2, immagine 1 di 2 HP OfficeJet 4650 Power Button Replacement: passo 2, immagine 2 di 2
      • Using the 2.0 mm hex screwdriver, remove the 14 mm hex screw that binds the front cover to the printer body by turning the screw counterclockwise.
      Chiedi a FixBot
      Aggiungi Commento
    3. HP OfficeJet 4650 Power Button Replacement: passo 3, immagine 1 di 3 HP OfficeJet 4650 Power Button Replacement: passo 3, immagine 2 di 3 HP OfficeJet 4650 Power Button Replacement: passo 3, immagine 3 di 3
      • Release the front panel from its internal hooks by applying a little force and sliding the front panel to the right.
      • Push the panel upward to remove it from the printer.
      • There is a connector attached to the back of the panel. Flip the front cover towards you gently and proceed to the next step.
      Chiedi a FixBot
      Aggiungi Commento
    4. HP OfficeJet 4650 Power Button Replacement: passo 4, immagine 1 di 3 HP OfficeJet 4650 Power Button Replacement: passo 4, immagine 2 di 3 HP OfficeJet 4650 Power Button Replacement: passo 4, immagine 3 di 3
      • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    5. HP OfficeJet 4650 Power Button Replacement: passo 5, immagine 1 di 3 HP OfficeJet 4650 Power Button Replacement: passo 5, immagine 2 di 3 HP OfficeJet 4650 Power Button Replacement: passo 5, immagine 3 di 3
      • Using the Torx T6 hex screwdriver, remove the 7.0mm screw that binds the front cover to the printer body by turning the screw counterclockwise.
      Chiedi a FixBot
      Aggiungi Commento
    6. HP OfficeJet 4650 Power Button Replacement: passo 6, immagine 1 di 3 HP OfficeJet 4650 Power Button Replacement: passo 6, immagine 2 di 3 HP OfficeJet 4650 Power Button Replacement: passo 6, immagine 3 di 3
      • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from button circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    7. HP OfficeJet 4650 Power Button Replacement: passo 7, immagine 1 di 3 HP OfficeJet 4650 Power Button Replacement: passo 7, immagine 2 di 3 HP OfficeJet 4650 Power Button Replacement: passo 7, immagine 3 di 3
      • Pop the button off from the black cover by using your finger tip to bring it up.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team S19-G6, Livingston Winter 2018 Membro di Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
3 Membri
10 guide realizzate
6Commenti sulla guida
Does this fix the printer not turning on?
cindim - Rispondi Condividi
Where can I purchase the replacement Power Button? What is the part number?
Mort Rosenberg - Rispondi Condividi
Is it possible to bypass the malfunctioning power button, so the printer is on whenever it is plugged in? If so, how?
Ron Sela - Rispondi Condividi
Jack Farr
Jack Farr - Rispondi Condividi
Bonjour,
Ou peut on acheter l'écran tactile HP Officejet 4650 ???
Georges N'GUELA - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 40
Tutti i Tempi: 4,324
