Salta al contenuto principale
HP Notebook 15-ba018ds RAM Replacement
Cosa ti serve
    1. HP Notebook 15-ba018ds RAM Replacement, Battery: passo 1, immagine 1 di 1
      • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
      • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
      Chiedi a FixBot
      Aggiungi Commento
    2. HP Notebook 15-ba018ds RAM Replacement: passo 2, immagine 1 di 3 HP Notebook 15-ba018ds RAM Replacement: passo 2, immagine 2 di 3 HP Notebook 15-ba018ds RAM Replacement: passo 2, immagine 3 di 3
      • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
      • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
      Chiedi a FixBot
      Aggiungi Commento
    1. HP Notebook 15-ba018ds RAM Replacement, RAM: passo 3, immagine 1 di 2 HP Notebook 15-ba018ds RAM Replacement, RAM: passo 3, immagine 2 di 2
      • Unscrew the 8 screws on the back cover.
      • There are also two screws in the battery area that you unscrew.
      Chiedi a FixBot
      Aggiungi Commento
    2. HP Notebook 15-ba018ds RAM Replacement: passo 4, immagine 1 di 1
      • Use an opening tool and wedge it under the edge and go around the whole laptop to help remove the back cover.
      • On the side of the laptop, you can see where it can be separated into two parts.
      Chiedi a FixBot
      Aggiungi Commento
    3. HP Notebook 15-ba018ds RAM Replacement: passo 5, immagine 1 di 3 HP Notebook 15-ba018ds RAM Replacement: passo 5, immagine 2 di 3 HP Notebook 15-ba018ds RAM Replacement: passo 5, immagine 3 di 3
      • This laptop has one RAM.
      • Gently pull out the RAM from the socket.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 12
Ultimi 30 giorni: 33
Tutti i Tempi: 1,623
