Salta al contenuto principale
HP G62-223CL RAM Replacement
Cosa ti serve
  1. HP G62-223CL RAM Replacement, Battery Removal: passo 1, immagine 1 di 2 HP G62-223CL RAM Replacement, Battery Removal: passo 1, immagine 2 di 2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP G62-223CL RAM Replacement: passo 2, immagine 1 di 1
    • Carefully remove the battery from its compartment.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP G62-223CL RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Locate three Phillips head retaining screws which secure RAM compartment.
    • Use a Phillips #0 screwdriver to loosen the screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP G62-223CL RAM Replacement: passo 4, immagine 1 di 2 HP G62-223CL RAM Replacement: passo 4, immagine 2 di 2
    • Use the tip of a screw driver to press the release clips away from the RAM module.
    • Once the second clip is released, the module will automatically pop up.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP G62-223CL RAM Replacement: passo 5, immagine 1 di 1
    • Carefully remove module from slot.
    • Be careful not to damage modules when removing them from their slots.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP G62-223CL RAM Replacement: passo 6, immagine 1 di 2 HP G62-223CL RAM Replacement: passo 6, immagine 2 di 2
    • Repeat steps 4 and 5 for additional RAM modules.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
USF Tampa, Team 1-4, Sullivan Winter 2015 Membro di USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 20
Tutti i Tempi: 946
