Salta al contenuto principale
HP Flyer Red Keyboard Replacement
Cosa ti serve
  1. HP Flyer Red Keyboard Replacement, Battery: passo 1, immagine 1 di 2 HP Flyer Red Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP Flyer Red Keyboard Replacement: passo 2, immagine 1 di 1
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP Flyer Red Keyboard Replacement: passo 3, immagine 1 di 2 HP Flyer Red Keyboard Replacement: passo 3, immagine 2 di 2
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP Flyer Red Keyboard Replacement: passo 4, immagine 1 di 1
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP Flyer Red Keyboard Replacement, Keyboard: passo 5, immagine 1 di 2 HP Flyer Red Keyboard Replacement, Keyboard: passo 5, immagine 2 di 2
    • Next locate and unscrew the two 4mm Phllips #1 screws with the keyboard symbol located towards the middle and top of the bottom of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP Flyer Red Keyboard Replacement: passo 6, immagine 1 di 3 HP Flyer Red Keyboard Replacement: passo 6, immagine 2 di 3 HP Flyer Red Keyboard Replacement: passo 6, immagine 3 di 3
    • Next turn the laptop over and flip open the screen.
    • Use the plastic opening tool to pry the keyboard upwards from the bottom right hand corner of the keyboard.
    • Use another plastic opening tool with the first plastic opening tool you placed to undo every plastic clasp surrounding the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP Flyer Red Keyboard Replacement: passo 7, immagine 1 di 3 HP Flyer Red Keyboard Replacement: passo 7, immagine 2 di 3 HP Flyer Red Keyboard Replacement: passo 7, immagine 3 di 3
    • Next lift up the keyboard gently and use the plastic opening tool to undo the ribbon wire by unclasping the ZIF (zero insertion force) connector to the laptop.
    • Gently slide the ribbon wire out of its slot.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 35
Tutti i Tempi: 2,603
