Salta al contenuto principale
HP Flyer Red Battery Replacement
  1. HP Flyer Red Battery Replacement, Battery: passo 1, immagine 1 di 2 HP Flyer Red Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP Flyer Red Battery Replacement: passo 2, immagine 1 di 1
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP Flyer Red Battery Replacement: passo 3, immagine 1 di 2 HP Flyer Red Battery Replacement: passo 3, immagine 2 di 2
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP Flyer Red Battery Replacement: passo 4, immagine 1 di 1
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
1Commento della guida
What do you do when the battery not charging but the laptop is working when directly plugged on power
liberty siegmann derera - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 12
Ultimi 30 giorni: 39
Tutti i Tempi: 2,726
