Salta al contenuto principale
HP Elitebook x360 1040 G5 Battery Replacement
Cosa ti serve
  1. HP Elitebook x360 1040 G5 Battery Replacement, Lower Case: passo 1, immagine 1 di 2 HP Elitebook x360 1040 G5 Battery Replacement, Lower Case: passo 1, immagine 2 di 2
    • Power off device before disassembly.
    • Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
  2. HP Elitebook x360 1040 G5 Battery Replacement: passo 2, immagine 1 di 2 HP Elitebook x360 1040 G5 Battery Replacement: passo 2, immagine 2 di 2
    • Pry open the lower case from where it meets the laptop base.
    • Remove the lower case from the work area.
  3. HP Elitebook x360 1040 G5 Battery Replacement, Battery: passo 3, immagine 1 di 2 HP Elitebook x360 1040 G5 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Use the Phillips 1 screwdriver to remove the five 3mm Phillips screws from the battery assembly.
  4. HP Elitebook x360 1040 G5 Battery Replacement: passo 4, immagine 1 di 3 HP Elitebook x360 1040 G5 Battery Replacement: passo 4, immagine 2 di 3 HP Elitebook x360 1040 G5 Battery Replacement: passo 4, immagine 3 di 3
    • Carefully remove the power supply connector by pulling on both sides of its head.
    • Do not tug on the wires as they may become damaged.
    • Lift the battery from its position, removing it from the device.
Conclusione
Corey Agena
Membro da: 04/21/19
833 Reputazione
6 Guide realizzate
Cal Poly, Team S1-G4, Maness Spring 2019 Membro di Cal Poly, Team S1-G4, Maness Spring 2019
CPSU-MANESS-S19S1G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 35
Tutti i Tempi: 2,608
