Salta al contenuto principale
HP EliteBook x360 830 G6 SSD Replacement
Cosa ti serve
  1. HP EliteBook x360 830 G6 SSD Replacement, Unfasten the back cover: passo 1, immagine 1 di 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 SSD Replacement, Release the clips: passo 2, immagine 1 di 2 HP EliteBook x360 830 G6 SSD Replacement, Release the clips: passo 2, immagine 2 di 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 SSD Replacement, Release the remaining clips: passo 3, immagine 1 di 2 HP EliteBook x360 830 G6 SSD Replacement, Release the remaining clips: passo 3, immagine 2 di 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 SSD Replacement, Remove the back cover: passo 4, immagine 1 di 3 HP EliteBook x360 830 G6 SSD Replacement, Remove the back cover: passo 4, immagine 2 di 3 HP EliteBook x360 830 G6 SSD Replacement, Remove the back cover: passo 4, immagine 3 di 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 SSD Replacement, Disconnect the battery: passo 5, immagine 1 di 3 HP EliteBook x360 830 G6 SSD Replacement, Disconnect the battery: passo 5, immagine 2 di 3 HP EliteBook x360 830 G6 SSD Replacement, Disconnect the battery: passo 5, immagine 3 di 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 SSD Replacement, Disconnect the SSD cover: passo 6, immagine 1 di 3 HP EliteBook x360 830 G6 SSD Replacement, Disconnect the SSD cover: passo 6, immagine 2 di 3 HP EliteBook x360 830 G6 SSD Replacement, Disconnect the SSD cover: passo 6, immagine 3 di 3
    • With your spudger, pry up on the tabs at the top and bottom of the SSD cover.
    • This will loosen the SSD cover enough for it to pop out from its tension clips.
  7. HP EliteBook x360 830 G6 SSD Replacement, Remove the SSD cover: passo 7, immagine 1 di 2 HP EliteBook x360 830 G6 SSD Replacement, Remove the SSD cover: passo 7, immagine 2 di 2
    • Lift the SSD cover off the SSD and remove it.
  8. HP EliteBook x360 830 G6 SSD Replacement, Unfasten the SSD: passo 8, immagine 1 di 2 HP EliteBook x360 830 G6 SSD Replacement, Unfasten the SSD: passo 8, immagine 2 di 2
    • Use your Phillips screwdriver to remove the 2.4 mm-long screw from the SSD.
  9. HP EliteBook x360 830 G6 SSD Replacement, Remove the SSD: passo 9, immagine 1 di 3 HP EliteBook x360 830 G6 SSD Replacement, Remove the SSD: passo 9, immagine 2 di 3 HP EliteBook x360 830 G6 SSD Replacement, Remove the SSD: passo 9, immagine 3 di 3
    • Grip the edges if the SSD near the screw indent.
    • Pull the SSD straight out of its socket and remove it.
    • If the SSD feels stuck, wiggle it side to side as you pull.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Clay Eickemeyer
Membro da: 09/19/22
81.656 Reputazione
455 Guide realizzate
Guide Team Membro di Guide Team
Staff
9 Membri
11.414 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 45
Ultimi 30 Giorni: 114
Tutti i Tempi: 2,941
