Salta al contenuto principale
HP EliteBook x360 830 G6 Cooling System Replacement
Cosa ti serve
  1. HP EliteBook x360 830 G6 Cooling System Replacement, Unfasten the back cover: passo 1, immagine 1 di 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Cooling System Replacement, Release the clips: passo 2, immagine 1 di 2 HP EliteBook x360 830 G6 Cooling System Replacement, Release the clips: passo 2, immagine 2 di 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Cooling System Replacement, Release the remaining clips: passo 3, immagine 1 di 2 HP EliteBook x360 830 G6 Cooling System Replacement, Release the remaining clips: passo 3, immagine 2 di 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: passo 4, immagine 1 di 3 HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: passo 4, immagine 2 di 3 HP EliteBook x360 830 G6 Cooling System Replacement, Remove the back cover: passo 4, immagine 3 di 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: passo 5, immagine 1 di 3 HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: passo 5, immagine 2 di 3 HP EliteBook x360 830 G6 Cooling System Replacement, Disconnect the battery: passo 5, immagine 3 di 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: passo 6, immagine 1 di 3 HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: passo 6, immagine 2 di 3 HP EliteBook x360 830 G6 Cooling System Replacement, Cooling System: passo 6, immagine 3 di 3
    • Using the Phillips #0 screwdriver, remove the seven 3 mm screws from the cooling system.
  7. HP EliteBook x360 830 G6 Cooling System Replacement: passo 7, immagine 1 di 3 HP EliteBook x360 830 G6 Cooling System Replacement: passo 7, immagine 2 di 3 HP EliteBook x360 830 G6 Cooling System Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the three 3mm captive screws from the fan using the Philips 0 screwdriver.
    • Using needle nose tweezers, gently grab the base of the connection and pull to disconnect.
  8. HP EliteBook x360 830 G6 Cooling System Replacement: passo 8, immagine 1 di 1
    • Separate the fan and cooling system from the motherboard.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Bukari
Membro da: 09/01/21
97 Reputazione
1 Guida realizzata
Gateway, Team 1-2, Saknee Fall 2021 Membro di Gateway, Team 1-2, Saknee Fall 2021
GCC-SAKNEE-F21S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 44
Tutti i Tempi: 581
