Salta al contenuto principale
HP EliteBook 835 G7 Lower Case Replacement
Cosa ti serve
  1. HP EliteBook 835 G7 Lower Case Replacement, Remove the Phillips screws: passo 1, immagine 1 di 2 HP EliteBook 835 G7 Lower Case Replacement, Remove the Phillips screws: passo 1, immagine 2 di 2
    • Completely power off and unplug your EliteBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a Phillips screwdriver to loosen the five captive screws from the lower case.
  2. HP EliteBook 835 G7 Lower Case Replacement, Release the case's right clips: passo 2, immagine 1 di 3 HP EliteBook 835 G7 Lower Case Replacement, Release the case's right clips: passo 2, immagine 2 di 3 HP EliteBook 835 G7 Lower Case Replacement, Release the case's right clips: passo 2, immagine 3 di 3
    • Insert an opening pick between the lower case and the chassis along the hinge edge.
    • Slide the opening pick around the right corner and halfway up the side of the EliteBook to release the clips securing the lower case.
  3. HP EliteBook 835 G7 Lower Case Replacement, Release the case's left clips: passo 3, immagine 1 di 3 HP EliteBook 835 G7 Lower Case Replacement, Release the case's left clips: passo 3, immagine 2 di 3 HP EliteBook 835 G7 Lower Case Replacement, Release the case's left clips: passo 3, immagine 3 di 3
    • Repeat the previous step on the left side of the case to release the clips.
  4. HP EliteBook 835 G7 Lower Case Replacement, Remove the lower case: passo 4, immagine 1 di 3 HP EliteBook 835 G7 Lower Case Replacement, Remove the lower case: passo 4, immagine 2 di 3 HP EliteBook 835 G7 Lower Case Replacement, Remove the lower case: passo 4, immagine 3 di 3
    • Lift the lower case up and away from the EliteBook and remove it.
Conclusione
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our HP Elitebook answers community for help.
Spencer Day
Membro da: 09/14/22
95.676 Reputazione
662 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.537 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 37
Tutti i Tempi: 497
