Salta al contenuto principale
HP Compaq nc8430 RAM Replacement
Cosa ti serve
  1. HP Compaq nc8430 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP Compaq nc8430 RAM Replacement: passo 2, immagine 1 di 1
    • Slide up against the three lines the battery has.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP Compaq nc8430 RAM Replacement: passo 3, immagine 1 di 1
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP Compaq nc8430 RAM Replacement, Remove RAM cover: passo 4, immagine 1 di 1
    • Completely shut down the device and unplug any adapters and chords that are connected.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP Compaq nc8430 RAM Replacement: passo 5, immagine 1 di 1
    • Use a screwdriver to remove the single screw on the covering located on the back of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP Compaq nc8430 RAM Replacement, Locate RAM: passo 6, immagine 1 di 1
    • Locate the RAM after you remove the covering.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP Compaq nc8430 RAM Replacement, Push clamps aside: passo 7, immagine 1 di 1
    • Use fingers or tools to press the clamps that hold the RAM in to the side.
    Chiedi a FixBot
    Aggiungi Commento
  8. HP Compaq nc8430 RAM Replacement, Pull RAM up to remove: passo 8, immagine 1 di 1
    • Place your fingers firmly on the RAM and pull it up.
    Chiedi a FixBot
    Aggiungi Commento
  9. HP Compaq nc8430 RAM Replacement, Remove RAM: passo 9, immagine 1 di 1
    • Place fingers firmly on RAM and pull it to remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
bryan ingram
Membro da: 03/27/17
101 Reputazione
Una guida realizzata
1Commento della guida
umm fine, except there is another module under the keyboard , rather an important fact to be overlooking
bari - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 16
Tutti i Tempi: 1,082
