Salta al contenuto principale
HP Compaq nc6400 Bluetooth Module Replacement
Cosa ti serve
  1. HP Compaq nc6400 Bluetooth Module Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off and unplug laptop.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP Compaq nc6400 Bluetooth Module Replacement: passo 2, immagine 1 di 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP Compaq nc6400 Bluetooth Module Replacement: passo 3, immagine 1 di 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP Compaq nc6400 Bluetooth Module Replacement: passo 4, immagine 1 di 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP Compaq nc6400 Bluetooth Module Replacement, Bluetooth Module: passo 5, immagine 1 di 1
    • Flip the computer top down and locate the second to-the-right 1.2 Philips #1 screw in the bottom-left corner.
    • Remove the screw.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP Compaq nc6400 Bluetooth Module Replacement: passo 6, immagine 1 di 3 HP Compaq nc6400 Bluetooth Module Replacement: passo 6, immagine 2 di 3 HP Compaq nc6400 Bluetooth Module Replacement: passo 6, immagine 3 di 3
    • Lift the right side of the Bluetooth Module cover upwards.
    • Slide the spudger under the lifted case, and slide it left towards the closed end. The case will pop open and be removed from the compartment.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP Compaq nc6400 Bluetooth Module Replacement: passo 7, immagine 1 di 1
    • Locate the Bluetooth Module after removing the cover.
    • Using the spudger, push the module to the right (i.e. towards the screw hole).
    • Pull outwards and remove bluetooth module and wire from casing.
    Chiedi a FixBot
    Aggiungi Commento
  8. HP Compaq nc6400 Bluetooth Module Replacement: passo 8, immagine 1 di 2 HP Compaq nc6400 Bluetooth Module Replacement: passo 8, immagine 2 di 2
    • Once the module and wire are completely outside of the casing, gently pull apart the wire from the module clip.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 14-6, Forte Fall 2013 Membro di Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Membri
5 guide realizzate
1Commento della guida
Hi,
My HP nx9420 did not have the Bluetooth. I wish to install one. I got one from my old HP nx9420. it Part Number is 397922-001 but the actual laptop says it requires the 409993-001 are these module the same ?
thanks
Alain
Alain Bastien - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 36
Tutti i Tempi: 2,647
