Salta al contenuto principale
HP Compaq 515 Wireless Card Replacement
Cosa ti serve
  1. HP Compaq 515 Wireless Card Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip the laptop over to the backside. The Hard Drive is located on the bottom left.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP Compaq 515 Wireless Card Replacement: passo 2, immagine 1 di 1
    • Unscrew the two screws with a PH00 bit. This releases the hard drive.
    • The screws are held in place, so there is no need to worry about losing them
    Chiedi a FixBot
    Aggiungi Commento
  3. HP Compaq 515 Wireless Card Replacement: passo 3, immagine 1 di 1
    • Slide the hard drive case off in a horizontal motion away from the device to remove the hard drive.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP Compaq 515 Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 1
    • The wireless card is located on the bottom of the laptop, however the hard drive case must be removed in order to access the wireless card.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP Compaq 515 Wireless Card Replacement: passo 5, immagine 1 di 1
    • Unscrew the two screws holding the hard drive in place, using a PH00 bit.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP Compaq 515 Wireless Card Replacement: passo 6, immagine 1 di 2 HP Compaq 515 Wireless Card Replacement: passo 6, immagine 2 di 2
    • Slide the wireless card backing towards you to remove it from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP Compaq 515 Wireless Card Replacement: passo 7, immagine 1 di 1
    • Gently remove the black and white wires that are connected to the wireless card.
    • The wires are held firmly in place, so it may take some force to remove them. Be cautious when doing so as the wires may tear or fray
    Chiedi a FixBot
    Aggiungi Commento
  8. HP Compaq 515 Wireless Card Replacement: passo 8, immagine 1 di 1
    • Remove the two .4 cm screws with a PH00 bit.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Aleks B
Membro da: 03/19/18
337 Reputazione
3 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 22
Tutti i Tempi: 549
