Salta al contenuto principale
HP Chromebook 14-Q010DX Motherboard Replacement
Cosa ti serve
  1. HP Chromebook 14-Q010DX Motherboard Replacement, Keyboard and Touchpad: passo 1, immagine 1 di 2 HP Chromebook 14-Q010DX Motherboard Replacement, Keyboard and Touchpad: passo 1, immagine 2 di 2
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP Chromebook 14-Q010DX Motherboard Replacement: passo 2, immagine 1 di 3 HP Chromebook 14-Q010DX Motherboard Replacement: passo 2, immagine 2 di 3 HP Chromebook 14-Q010DX Motherboard Replacement: passo 2, immagine 3 di 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP Chromebook 14-Q010DX Motherboard Replacement: passo 3, immagine 1 di 3 HP Chromebook 14-Q010DX Motherboard Replacement: passo 3, immagine 2 di 3 HP Chromebook 14-Q010DX Motherboard Replacement: passo 3, immagine 3 di 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP Chromebook 14-Q010DX Motherboard Replacement: passo 4, immagine 1 di 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP Chromebook 14-Q010DX Motherboard Replacement: passo 5, immagine 1 di 1
    • Set aside the detached keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: passo 6, immagine 1 di 3 HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: passo 6, immagine 2 di 3 HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: passo 6, immagine 3 di 3
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP Chromebook 14-Q010DX Motherboard Replacement: passo 7, immagine 1 di 2 HP Chromebook 14-Q010DX Motherboard Replacement: passo 7, immagine 2 di 2
    • Gently remove the speakers.
    Chiedi a FixBot
    Aggiungi Commento
  8. HP Chromebook 14-Q010DX Motherboard Replacement, Battery: passo 8, immagine 1 di 2 HP Chromebook 14-Q010DX Motherboard Replacement, Battery: passo 8, immagine 2 di 2
    • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
    • Lift the black flaps and gently pull the strip out.
    • Set the strip aside.
    Chiedi a FixBot
    Aggiungi Commento
  9. HP Chromebook 14-Q010DX Motherboard Replacement: passo 9, immagine 1 di 3 HP Chromebook 14-Q010DX Motherboard Replacement: passo 9, immagine 2 di 3 HP Chromebook 14-Q010DX Motherboard Replacement: passo 9, immagine 3 di 3
    • Remove the screw.
    • Use your fingers to pull the white tab out of the black slot above the battery.
    Chiedi a FixBot
    Aggiungi Commento
  10. HP Chromebook 14-Q010DX Motherboard Replacement: passo 10, immagine 1 di 1
    • Gently remove battery.
    Chiedi a FixBot
    Aggiungi Commento
  11. HP Chromebook 14-Q010DX Motherboard Replacement, Bluetooth and Wireless Card: passo 11, immagine 1 di 2 HP Chromebook 14-Q010DX Motherboard Replacement, Bluetooth and Wireless Card: passo 11, immagine 2 di 2
    • Using a spudger, remove the white and black cables from the card.
    Chiedi a FixBot
    Aggiungi Commento
  12. HP Chromebook 14-Q010DX Motherboard Replacement: passo 12, immagine 1 di 2 HP Chromebook 14-Q010DX Motherboard Replacement: passo 12, immagine 2 di 2
    • Remove screw from card.
    Chiedi a FixBot
    Aggiungi Commento
  13. HP Chromebook 14-Q010DX Motherboard Replacement: passo 13, immagine 1 di 1
    • Gently pull card at a 45° angle to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  14. HP Chromebook 14-Q010DX Motherboard Replacement, Fan replacement for a HP Chromebook: passo 14, immagine 1 di 3 HP Chromebook 14-Q010DX Motherboard Replacement, Fan replacement for a HP Chromebook: passo 14, immagine 2 di 3 HP Chromebook 14-Q010DX Motherboard Replacement, Fan replacement for a HP Chromebook: passo 14, immagine 3 di 3
    • Remove the 3 screws around the fan.
    • Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  15. HP Chromebook 14-Q010DX Motherboard Replacement: passo 15, immagine 1 di 1
    • Once the cable connecting the fan to the motherboard is revomed gently remove fan with hands.
    Chiedi a FixBot
    Aggiungi Commento
  16. HP Chromebook 14-Q010DX Motherboard Replacement, Motherboard: passo 16, immagine 1 di 2 HP Chromebook 14-Q010DX Motherboard Replacement, Motherboard: passo 16, immagine 2 di 2
    • Using your fingers or spudger, pull out the connector.
    Chiedi a FixBot
    Aggiungi Commento
  17. HP Chromebook 14-Q010DX Motherboard Replacement: passo 17, immagine 1 di 3 HP Chromebook 14-Q010DX Motherboard Replacement: passo 17, immagine 2 di 3 HP Chromebook 14-Q010DX Motherboard Replacement: passo 17, immagine 3 di 3
    • Remove all of the indicated screws.
    • Pull up on black strip to remove the monitor cord.
    Chiedi a FixBot
    Aggiungi Commento
  18. HP Chromebook 14-Q010DX Motherboard Replacement: passo 18, immagine 1 di 1
    • Gently remove motherboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Kevin Piper
Membro da: 01/16/15
1.602 Reputazione
6 guide realizzate
USF Tampa, Team 17-2, Watkins Winter 2015 Membro di USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Membri
8 guide realizzate
4Commenti sulla guida
Can someone just explain for what the sensor board is needed?
martindoerflinger - Rispondi Condividi
Let's the motherboard know when the lid is closed.
Jeff Briedwell - Rispondi Condividi
Hi! How do you start a chrome book from motherboard? Since I am doing a project I need help with that question.... Please send a mail with the explanation on my mail: steffe010929@gmail.con
Stefan - Rispondi Condividi
hope some one is still maintaining this site, i would like to know if i would be able to use a motherboard from another HP chromebook in the same product line for example if i have a motherboard from the 14-q010dx can i swap it with the motherboard from the 14-q010nr? thevet82@gmail.com
david saldivias - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 24
Tutti i Tempi: 5,115
