Salta al contenuto principale
HP Chromebook 14-Q010DX Fan Replacement
Cosa ti serve
  1. HP Chromebook 14-Q010DX Fan Replacement, Keyboard and Touchpad: passo 1, immagine 1 di 2 HP Chromebook 14-Q010DX Fan Replacement, Keyboard and Touchpad: passo 1, immagine 2 di 2
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP Chromebook 14-Q010DX Fan Replacement: passo 2, immagine 1 di 3 HP Chromebook 14-Q010DX Fan Replacement: passo 2, immagine 2 di 3 HP Chromebook 14-Q010DX Fan Replacement: passo 2, immagine 3 di 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP Chromebook 14-Q010DX Fan Replacement: passo 3, immagine 1 di 3 HP Chromebook 14-Q010DX Fan Replacement: passo 3, immagine 2 di 3 HP Chromebook 14-Q010DX Fan Replacement: passo 3, immagine 3 di 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP Chromebook 14-Q010DX Fan Replacement: passo 4, immagine 1 di 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP Chromebook 14-Q010DX Fan Replacement: passo 5, immagine 1 di 1
    • Set aside the detached keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP Chromebook 14-Q010DX Fan Replacement, Fan replacement for a HP Chromebook: passo 6, immagine 1 di 3 HP Chromebook 14-Q010DX Fan Replacement, Fan replacement for a HP Chromebook: passo 6, immagine 2 di 3 HP Chromebook 14-Q010DX Fan Replacement, Fan replacement for a HP Chromebook: passo 6, immagine 3 di 3
    • Remove the 3 screws around the fan.
    • Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP Chromebook 14-Q010DX Fan Replacement: passo 7, immagine 1 di 1
    • Once the cable connecting the fan to the motherboard is revomed gently remove fan with hands.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Kevin Piper
Membro da: 01/16/15
1.602 Reputazione
6 guide realizzate
USF Tampa, Team 17-2, Watkins Winter 2015 Membro di USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Membri
8 guide realizzate
1Commento della guida
Add Comment:
Akshit Fnu - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 38
Tutti i Tempi: 4,271
