Salta al contenuto principale
HP Chromebook 11 G8 EE Battery Replacement
Cosa ti serve
  1. HP Chromebook 11 G8 EE Battery Replacement, Keyboard & Touchpad Assembly: passo 1, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Battery Replacement: passo 2, immagine 1 di 2 HP Chromebook 11 G8 EE Battery Replacement: passo 2, immagine 2 di 2
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Battery Replacement: passo 3, immagine 1 di 3 HP Chromebook 11 G8 EE Battery Replacement: passo 3, immagine 2 di 3 HP Chromebook 11 G8 EE Battery Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Do not puncture or damage any parts of the battery.
    • Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
    • The speakers are removed in these images, but they don't need to be to replace the battery.
  5. HP Chromebook 11 G8 EE Battery Replacement: passo 5, immagine 1 di 3 HP Chromebook 11 G8 EE Battery Replacement: passo 5, immagine 2 di 3 HP Chromebook 11 G8 EE Battery Replacement: passo 5, immagine 3 di 3
    • Remove the four 3.5 mm Phillips #1 screws securing the battery.
    • If you've already removed the speakers, you'll only need to remove the two screws on the top of the battery, near the motherboard.
  6. HP Chromebook 11 G8 EE Battery Replacement: passo 6, immagine 1 di 2 HP Chromebook 11 G8 EE Battery Replacement: passo 6, immagine 2 di 2
    • Carefully lift the battery up and out.
Conclusione
Julia Latura
Membro da: 10/25/22
328 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Membro di UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
5 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 54
Tutti i Tempi: 820
