Salta al contenuto principale
HP 7 1800 Display Replacement
Cosa ti serve
    1. HP 7 1800 Display Replacement, Remove the back panel: passo 1, immagine 1 di 2 HP 7 1800 Display Replacement, Remove the back panel: passo 1, immagine 2 di 2
      • Carefully insert a Spudger into one of the corners of the tablet.
      • Slide the Spudger along the edge popping the tabs out along the way.
      • Be careful not to break the tabs.
      Chiedi a FixBot
      Aggiungi Commento
    2. HP 7 1800 Display Replacement, Remove the battery: passo 2, immagine 1 di 3 HP 7 1800 Display Replacement, Remove the battery: passo 2, immagine 2 di 3 HP 7 1800 Display Replacement, Remove the battery: passo 2, immagine 3 di 3
      Strumento utilizzato in questo passaggio:
      • Slide the Spudger under the battery to lift it off the adhesive.
      • Gently pull the cable connection from the motherboard using tweezers.
      Chiedi a FixBot
      Aggiungi Commento
    1. HP 7 1800 Display Replacement, Remove the large ribbon cable: passo 3, immagine 1 di 2 HP 7 1800 Display Replacement, Remove the large ribbon cable: passo 3, immagine 2 di 2
      • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
      Chiedi a FixBot
      Aggiungi Commento
    2. HP 7 1800 Display Replacement, Remove the smaller ribbon cable: passo 4, immagine 1 di 2 HP 7 1800 Display Replacement, Remove the smaller ribbon cable: passo 4, immagine 2 di 2
      • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
      Chiedi a FixBot
      Aggiungi Commento
    3. HP 7 1800 Display Replacement, Unscrew the 7 silver screws from the logic board: passo 5, immagine 1 di 1
      • Remove the following 7 screws:
      • Six 4.17mm Phillips #00 around the motherboard.
      • One 2.67mm Phillips #00 next to the front facing camera.
      • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
      Chiedi a FixBot
      Aggiungi Commento
    4. HP 7 1800 Display Replacement, Unplug the front facing camera from the logic board: passo 6, immagine 1 di 1
      • Gently pry the front facing camera plug up and off of the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    5. HP 7 1800 Display Replacement, Remove the logic board: passo 7, immagine 1 di 1
      • Carefully lift the motherboard directly up.
      Chiedi a FixBot
      Aggiungi Commento
    1. HP 7 1800 Display Replacement, Remove the ribbon cable attached to the metal plate: passo 8, immagine 1 di 2 HP 7 1800 Display Replacement, Remove the ribbon cable attached to the metal plate: passo 8, immagine 2 di 2
      • On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out.
      Chiedi a FixBot
      Aggiungi Commento
    2. HP 7 1800 Display Replacement, Unscrew the 7 black screws on the metal plate: passo 9, immagine 1 di 1
      • Unscrew the following black screws:
      • Seven 2.82mm Phillips #00 around the metal casing.
      Chiedi a FixBot
      Aggiungi Commento
    3. HP 7 1800 Display Replacement, Remove the metal plate: passo 10, immagine 1 di 1
      • Gently lift the metal plate directly up.
      Chiedi a FixBot
      Aggiungi Commento
    4. HP 7 1800 Display Replacement, Remove the display: passo 11, immagine 1 di 1
      • Gently lift the display directly up.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
TMD
Membro da: 01/21/15
792 Reputazione
5 guide realizzate
USF Tampa, Team 4-1, Brown Winter 2015 Membro di USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Membri
14 guide realizzate
2Commenti sulla guida
I have this same tablet but I cannot find a replacement screen. Do you know where I could find one?
Karen Porter - Rispondi Condividi
I have the same problem
akiel panchan - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 21
Tutti i Tempi: 2,256
