Salta al contenuto principale
HP 15-g029wm Battery Replacement
  1. HP 15-g029wm Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug any charging cord or accessories connected to the device before beginning.
  2. HP 15-g029wm Battery Replacement: passo 2, immagine 1 di 1
    • Place the laptop bottom-side up on a secure, flat surface.
  3. HP 15-g029wm Battery Replacement: passo 3, immagine 1 di 3 HP 15-g029wm Battery Replacement: passo 3, immagine 2 di 3 HP 15-g029wm Battery Replacement: passo 3, immagine 3 di 3
    • Slide each of the two switches that secure the battery to the left.
    • This will reveal an image of an unlocked lock.
  4. HP 15-g029wm Battery Replacement: passo 4, immagine 1 di 3 HP 15-g029wm Battery Replacement: passo 4, immagine 2 di 3 HP 15-g029wm Battery Replacement: passo 4, immagine 3 di 3
    • Use your hands to gently pull the disconnected battery out of the device.
    • When inserting the new battery, pay special attention to align the battery connections correctly.
Conclusione
For optimal performance, calibrate your newly installed battery after completing this guide.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 120
