Salta al contenuto principale
HP 15-R263DX RAM Replacement
Cosa ti serve
  1. HP 15-R263DX RAM Replacement, Battery: passo 1, immagine 1 di 2 HP 15-R263DX RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP 15-R263DX RAM Replacement, Optical Drive: passo 2, immagine 1 di 2 HP 15-R263DX RAM Replacement, Optical Drive: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP 15-R263DX RAM Replacement: passo 3, immagine 1 di 1
    • Gently slide the optical drive out of the side of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP 15-R263DX RAM Replacement, HP 15-R263DX Disassembly: passo 4, immagine 1 di 2 HP 15-R263DX RAM Replacement, HP 15-R263DX Disassembly: passo 4, immagine 2 di 2
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP 15-R263DX RAM Replacement: passo 5, immagine 1 di 1
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP 15-R263DX RAM Replacement: passo 6, immagine 1 di 1
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
    Chiedi a FixBot
    Aggiungi Commento
  7. HP 15-R263DX RAM Replacement: passo 7, immagine 1 di 2 HP 15-R263DX RAM Replacement: passo 7, immagine 2 di 2
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
    Chiedi a FixBot
    Aggiungi Commento
  8. HP 15-R263DX RAM Replacement: passo 8, immagine 1 di 2 HP 15-R263DX RAM Replacement: passo 8, immagine 2 di 2
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
    Chiedi a FixBot
    Aggiungi Commento
  9. HP 15-R263DX RAM Replacement: passo 9, immagine 1 di 1
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
    Chiedi a FixBot
    Aggiungi Commento
  10. HP 15-R263DX RAM Replacement, Hard Drive: passo 10, immagine 1 di 1
    • Remove the 2 black screws holding the hard drive to the computer frame.
    Chiedi a FixBot
    Aggiungi Commento
  11. HP 15-R263DX RAM Replacement: passo 11, immagine 1 di 2 HP 15-R263DX RAM Replacement: passo 11, immagine 2 di 2
    • Gently slide the hard drive away from the motherboard to disconnect it.
    • After it's disconnected, lift the hard drive up to remove it from the computer.
    Chiedi a FixBot
    Aggiungi Commento
  12. HP 15-R263DX RAM Replacement, RAM: passo 12, immagine 1 di 1
    • Remove the 2 screws holding the motherboard into the case of the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  13. HP 15-R263DX RAM Replacement: passo 13, immagine 1 di 2 HP 15-R263DX RAM Replacement: passo 13, immagine 2 di 2
    • Remove the connections around the motherboard.
    • There is a connection hidden underneath the board. Remove this one last as you will need to lift the motherboard up to access it.
    Chiedi a FixBot
    Aggiungi Commento
  14. HP 15-R263DX RAM Replacement: passo 14, immagine 1 di 2 HP 15-R263DX RAM Replacement: passo 14, immagine 2 di 2
    • Remove the screw holding the WiFi chip in place.
    • Slide the chip away from the motherboard and set it elsewhere inside the computer.
    Chiedi a FixBot
    Aggiungi Commento
  15. HP 15-R263DX RAM Replacement: passo 15, immagine 1 di 1
    • Flip the motherboard over to access the underside revealing the RAM.
    Chiedi a FixBot
    Aggiungi Commento
  16. HP 15-R263DX RAM Replacement: passo 16, immagine 1 di 2 HP 15-R263DX RAM Replacement: passo 16, immagine 2 di 2
    • Remove the RAM chip by simultaneously prying the 2 spring clips away from the RAM.
    • The RAM will pop up when both clips are completely released.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
1Commento della guida
is this laptop model ram upgradable?
Gordon Velupillai - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 34
Tutti i Tempi: 1,908
